Question about Cell Phones
Trying to calibrate my IB-TR1000FH thermostat. It is unlocked, though after mashing the sun & moon buttons for 3 seconds, the temp doesn't flash...it was working last week?
Not working
  • Mia Cox
    Mia Cox Jan 07, 2013
    lol, it a thermostat, not a phone! I got it working, Thanx!
SOURCE: "3 second" light flashing
The 3 second flashing light is a lock that locks out all other functions. To disable, depress the 3 second light for 3 seconds and all the functions will be released. This feature is to use to keep little kids from starting the appliance.
Posted on Jul 04, 2007
tantong
  • 138 Answers
SOURCE: Screen's gone blank and the green power button flashes intermittently
This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
SOURCE: Toshiba Satellite Pro 4200 stuck in hibernate.
I have a toshiba satellite pro 4200. I have put a new memory module 128MB in in addition to the 64MB memory that was already in. The system does not recognise the 128 and the 64 modules when installed together. Do the two modules have to be of the same value i.e. 128 or 64 or is there another way of getting the system to recognise both modules. Many thanks BB
Posted on Apr 30, 2010
budmrtn
  • 11361 Answers
SOURCE: My monitor turns black automatically after about 3
LCD monitor? More than 2 years old?
If yes, then read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 20, 2011
nova2nv
  • 197 Answers
SOURCE: on john deere 345 18 hp kawasaki liquid cooled
Water pump gear or the water pump impeller could have failed. If its the pump and due to it being at the bottom front side of the engine it would take some time for it to boil due to the fan is always pulling air down thru the radiator and its at the very top of engine. Cool water on top and really hot coolant around the cylinder with sensor. I'm sure it's the pump.
Posted on Jul 19, 2011
Calibrating Honeywell CT3600
In the thermostats setup there can be a calibration mode however this is a chasing the gragon type of endeavour that rarely ever culminates in thermostats jiving with another, they typically are off plus or minus 3-4 degrees anyways as they are not designed to maintain too narrow of a temperature differential or the furnace will short cycle or run too often & stop in short order.
Jun 29, 2013 | Heating & Cooling
How to unlock my samsung galaxy y GTS5360 too many patterns to attemps
Jan 05, 2013 | Samsung Galaxy Y Gt-s5360 - White unlocked...
Camera settings to shoot the moon
The best way is to set your camera to manual exposure and ignore the camera's light meter. The light meter will try to make the entire scene a middle gray, which will result in a gray sky with a blown-out moon.
There's an old rule-of-thumb called the "Sunny-16 Rule." This says that the proper exposure for a picture under a bright sun is f/16 at a shutter speed of 1/ISO seconds. So if you're shooting a daylight scene at ISO 200 then the proper exposure would be f/16 at 1/200 seconds or equivalent (such as f/11 at 1/400).
Why is this relevant? The moon is simply a large rock essentially at the same distance from the sun as any other landscape you've photographed. So start with f/16 at 1/ISO. Take a look at the result on the back of the camera. The sky will be completely black, but so what? It's the moon you want. Zoom in on it and see whether it looks the way you want it to. Adjust the exposure if necessary. Don't let it blow out to complete white.
May 28, 2012 | Cannon EOS 50D Digital Camera
No matter what button I press, it says 'locked' on the TV screen. How do I unlock it?
Try holding down the Menu button on the remote for at least 5 seconds, the child lock is on, If this doesn't work go to samsung website and find your user manual and follow the procedure they suggest.
Mar 06, 2012 | Samsung Televison & Video
How do i take picture of the moon
I assume you want a picture of the moon and don't particularly care what the sky looks like.
Consider a full moon. Just what are you taking a picture of? It's a landscape, right? Mountains, craters, etc. All under a bright midday sun without a cloud in the sky (the sky on the moon, not your sky). So what if the moon's a quarter of a million miles away from you, it's under the same sun. Yeah, it's a quarter of a million miles farther from the sun, but given the nearly one hundred million miles between the earth and the sun, the difference is negligible.
There's an old photography rule called the "Sunny-16 Rule." It says that the proper exposure under sunny conditions is f/16 at a shutter speed that is a reciprocal of the film's ISO rating. So, at ISO 200 the proper exposure would be f/16 at 1/200 second (or equivalent, such as f/11 at 1/400 second). You'll have to switch the camera to the Manual exposure mode to do this. Ignore anything the camera's light meter says.
Use this as a starting guideline. Take a picture and review it on the screen. Don't worry about the sky going pure black. You don't want the highlights to get blown out, or the moon will look like a white blob.
Feb 07, 2012 | Canon EOS 40D Digital SLR Camera Digital...
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
My pacific hot tub has LOC on the display and i cant adjust the jets or temp. Is the display locked and how do i unlock it?
Mike,
Yes LOC is a standard topside lock code.
Try these common unlock codes,
Press & Hold Jet Button for 6 seconds
or
Press & Hold Temp Up & Temp down for 6 seconds.
Possibly your jet button is faulty i.e. it is broken internally or when it is pressed the button sticks in the on position and locks out the panel.
If those common codes don't work let me know which brand/topside control your spa has and I will get a more specific answer.
Jan 16, 2012 | Pool & Spa
LG WD-10160 TP. Display is showing code CL and no buttons work. I think it may be child lock but can't turn it off. The problem occurred when I turned off the machine & disconnected the water...
You are quite right, the Child Lock is engaged.
3 options for you depending on the machine:
Find the two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that should reset it.
Or
It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Or
If it has a program selector twist dial, set the selector to off or the end of a program (If it doesn't have, don't worry) Then, unplug from the mains. Leave for 20 minutes without tampering.
Power back on and the machine should have reset
Jul 01, 2011 | LG Washing Machines
Un lock child lock 10d52 seimins washer dryer
to deactivate the child lock, set program to Easy-Care and hold option down arrow for 5 seconds. If still it does not get unlocked then Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds.
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD
Jun 26, 2011 | Washing Machines
I tried the solution outlined above. I very carefully followed the instructions, but never saw the "sun moon" symbols when pressing "Program" over and over. Any thoughts?
Which timer do you have??
You posted under ST01C timer >> this timer does not have a sun-moon button...
The Utilitec 0192773 timer has a sun-moon button
However the Utilitec 014224 does NOT have a sun-moon button
There are a lot of timers on the market, and each has different instructions
The following page may help you identify your timer
The page has manuals for many of the timers shown
http://waterheatertimer.org/Programmable.html
Answer this response, or re-post another question after you identify timer and get the correct manual
Oct 21, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
