Question about Kodak EasyShare Z650 Digital Camera
How do I format memory card for a kodak z650 - Kodak EasyShare Z650 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Use the format command in the setup menu. See this page of the user guide. Make sure you're using an SD or MMC card, 2GB or smaller. This camera will not work with higher-capacity SDHC cards.
Posted on Jan 07, 2013
Agent Allan
  • 480 Answers
SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 01, 2008
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Posted on Mar 28, 2009
  • 34 Answers
SOURCE: memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
Posted on Jun 09, 2009
Feist Geist
  • 73 Answers
SOURCE: My kodak easyshare c180 wont read a memory card
You should probably get a USB card reader, take the card out of your camera, put in the card and connect it to the computer. Then try formating the card through Windows using the FAT file system (not NTFS).
Posted on Apr 13, 2010
  • 102366 Answers
SOURCE: I need to format my 4gb sdhc card for my kodak
Unfortunately you can't. The Z650 is designed to work with SD cards. Your 4GB card is actually an SDHC card (the HC stands for High Capacity). While SDHC cards will fit into SD devices, they are electronically different and will not work.
SD cards will work in SDHC devices, but that doesn't help you here.
Posted on Jul 18, 2010
How to format sdhc memory card for kodak z650?
You can't. The Z650 works with MMC and SD cards. It does not work with SDHC cards.
Aug 07, 2014 | Kodak EasyShare Cameras
Why does the camera go to internal memory
Do you have a compatible memory card installed? Is the card formatted? Is there sufficient empty space on the card?
Dec 31, 2012 | Kodak EasyShare Z650 Digital Camera
MY CAMERA IS A Z650 KODAK EASYSHARE, MY DAUGHTER LOST MY OLD MEMORY CARD SO I WENT OUT AND BOUGHT A NEW MEMORY CARD BUT MY CAMERA SAYS IT NEEDS FORMATTING AND IT WONT LET ME ALSO IT SAYS INTERNAL MEMORY IS...
Just as I suggested. The Z650 works with SD cards, not SDHC cards. Most likely your old card was 2GB or smaller and your new card is 4GB or larger. Try using a 2GB SD card.
You can clear internal memory by deleting the pictures it contains. Download them to your computer first if you want to preserve them. You can get rid of all of them in one shot by using the "Format" command in the Setup menu.
Apr 27, 2012 | Kodak Cameras
My Z650 says "Memory card
The Z650 works with MMC and SD cards, not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. The M380 will work with SDHC cards, but the Z650 is limited to cards 2GB and smaller.
Jul 08, 2011 | Cameras
I have a kodak easyshare z650 and i cannot format an 8gb sd card,
The Z650 is designed to work with SD cards. Your 8GB card is actually an SDHC (Secure Digital High Capacity) card. While an SDHC card will fit into an SD slot, it will not work properly. You'll have to stay with SD cards 2GB and smaller.
Aug 12, 2010 | Kodak EasyShare C330 Digital Camera
Will my kodak z650 take a shdc memory card and how do i format it
No. The Z650 only takes SD cards, up to 2GB in size. You cannot format an SDHC card in one.
Jul 31, 2010 | Kodak EasyShare Z650 Digital Camera
Sdhc 8g card won't format in a kodak z650
The Z650 uses SD cards. SDHC cards will not work in the camera. You have to stay with SD cards, 2GB and smaller.
Jun 14, 2010 | Kodak Cameras
Placed a new sd-hc card in an Easyshare Z650, camera responds "Memory card requires formating" hit continue twice and formatting will not take place. what are my options?
go to the menu and push (format memory card) then a a warning will come up that says (Warning Formating card will erase all that is on the care) push OK and it should format in might take some time !!Good Luck!!:)
Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
Internal memory is full. How do I clear it from my Zodak EasyShare Z650 digital camera?
Turn On camera
-Press Menu, scroll down look for setup then press Ok button.
-Under setup menu scroll down again and look for format then press Ok Button
-Under format highlight or choose Internal Memory then press Ok button
-It will format or clear the internal memory
Gudluck!
Nov 04, 2009 | Kodak EasyShare Z650 Digital Camera
MAx SD size that works in a Z650 Digital camera
You can use 1GB SD card or 2GB SD card., more than 2GB is not compatible on your Z650., Gudluck!
Nov 28, 2008 | Kodak EasyShare Z650 Digital Camera
Kodak EasyShare Z650 Digital Camera Logo
269 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
