Question about Proform Exercise & Fitness
Proform 630ds shuts off while running on it
Hi. I have an old 630DS and it runs fine for about two minutes while I'm using it and then it just shuts off. It won't turn back on and I've tried unplugging it and then plugging it back in, to reset the current, but it doesn't work. This kind of sounds like a current problem, a short, or a problem with the motor. Any ideas?
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video and proceed according.+LUBE THE rollers bearing
Posted on Jan 07, 2013
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 10 Answers
SOURCE: my proform 830 qt circuit keeps flipping
I've been having this problem too and it seems the best solutions i've came up with have been to buy a lube kit for the treadmill from the proform website or replace the circuit breaker.
Posted on Sep 24, 2009
taran_2005
  • 10515 Answers
SOURCE: my proform 520 runs at high speeds & speeds up on its own
This seems to be an issue with Signal Generator.If you have a problem with the signal generator, your speed will be erratic with either a person on the machine or without a person on the machine. You may even get a speed error code from the unit.
The procedure to check the same is :-
http://www.treadmilldoctor.com/Signal-Generator-Test
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 12, 2009
SOURCE: proform 760 shuts off after running for 15
my wife has a proform 490gs that keeps shutting off after about 40 minutes by tripping the breaker. what is causing this.
Posted on Nov 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
Posted on May 06, 2010
Pro form 630ds just powers off
Check the walking belt, maybe it is creating much friction and you need a new belt. You can buy one on WalkingBelts.com
Dec 22, 2013 | Exercise & Fitness
Jerky when using
There may be a problem with the running belt being loose.
Or a motor problem.
Dec 13, 2013 | Proform 630ds Treadmill Front Roller
Transformer overheating
The motor probably need maintenance:LUBE+replacing brushes,bearing.see my personal TIPS for defective transformer+motor
However the main problem is LUBE see the video and proceeding according witht the DECK BELT+ROLLERS BEARING TOO.
Feb 04, 2013 | Proform 835 Qt Front Roller Model 299480
Timer runs 10 times speed
Try to power by locating circuit breaker that powers that area?
Nov 05, 2012 | KitchenAid KCMS2055SSS Microwave Oven
I have a Proform 630DS it will only run at full speed as soon as it is plugged in even with the safety key not insereted. Any solutions?
yes, Please RUN the software calibration inmediately for diagnose, troubleshooting, and fix it.
God bless you
Jul 12, 2012 | Exercise & Fitness
My 1995 Plymouth Neon will run fine as long as it's cool. But as soon as the temp outside comes up, it shuts off & will restart within a few minutes. If you do this very many times,, it just...
if car shuts off when hot outside, change thermostat and radiator pressure cap.-- heres more-car shuts off when tempurature of engine gets to normal. causes; low coolant, failing coolant temp. sensor, air in water pump. it takes 10-15 minutes to reach normal range. hope this helps! good-day!
Sep 01, 2011 | 1996 Plymouth Neon
Proform 760 shuts off after running for 15 minutes. Needs to cool off before it can be reset
Oct 30, 2009 | Proform 760 CrossTrainer Treadmill
My proform 520 runs at high speeds & speeds up on its own
Hope i helped you.
Oct 12, 2009 | Exercise & Fitness
My proform 830 qt circuit keeps flipping
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
170 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
