Question about Wascomat Parts Wascomat 231754 Dryer FLANGE,T3300S,TD3030 GAS VALVE - Wascomat Laund
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
  • Wascomat Parts Master
  • 8,220 Answers
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Posted on Jan 07, 2013
well the error E15 means that the dryer thinks it's overloaded. Spin the tub by hand and make sure it's spins smoothly. If so then you have a bad motor unfortunately.
May 27, 2015 | Dryers
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Ive got a d90d25eslr111-b1 micro combi,i poached an egg ani ie exploded in the micro,it blew the electic and went off,if i swith it on its ok,as soon as i shut the door it fuses the electric. why plea
see this causes and fix it. God bless you
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Sep 27, 2012 | Morphy Richards Microwave Ovens
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
1992 BUICK LA SABRE, PROBLEM AS FOLLOWS WE HAVE POWER TO THE BOTTOM OF THE STEERING COLUMN FROM IGNITION KEY SWITCH, BUT NO POWER FROM THE SWITCHES AT BOTTOM OF COLUMN TO STARTER SOLENOID, WE'VE TRIED...
it will only run for a few seconds if your key has a transponder that the security system looks for, the security system is tied into the ignition system for starter and ignition.
do you have a security light flashing on dash? if that is the case you have to leave the key in the on position until the light goes off, usually 10 - 15 minutes, once light goes off you should be able to start the engine unless the tumbler is bad, it has the part that reads the transponder in the key.
Oct 01, 2011 | Cars & Trucks
Maytag electric dryer shuts off mid- cycle. I've checked the lint screen and dryer vent to the outside. They're fine. The heat works. Just shuts off after 10 minutes or so.
you have a weak or failing thermostat ,, you can check them by doing this Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. be sure machine is unplugged before doing any electrical tests
Jul 06, 2011 | Maytag PYE2300AY Electric Dryer
Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
May 12, 2011 | Dryers
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Wascomat Parts Wascomat 231754 Dryer FLANGE,T3300S,TD3030 GAS VALVE - Wascomat Laund Logo
742 people viewed this question
Top Wascomat Parts Dryers Experts
Dan Webster
Dan Webster
Mai Lor
William Goodman
William Goodman
Level 1 Expert
Are you a Wascomat Parts Dryer Expert? Answer questions, earn points and help others
