Question about LG LFC21776ST 21 CF French Door Refer Cab Depth: LFC21776ST Refrigerator Stainless Steel
Problem with constant humming - LG LFC21776ST 21 CF French Door Refer Cab Depth: LFC21776ST Refrigerator Stainless Steel
How do I stop the constant hum coming from my Azden SGM-1X Professional Microphone?
If the hum is from line pickup, it should be 60hz or 120hz. If you are connecting to a line powered device, you might want to try a direct or isolation box. There's a ton of them like these
Passive Direct Boxes
And see if orienting the mic at a different angle. Try turning off fluorescent lights. Isolate ie as much as possible.
Jan 01, 2015 | Azden SGM-1X Shotgun Microphone
Omni S8 Subwoofer Constant Hum
4amom-s8n is the part number for the amp assembly
Apr 08, 2013 | Audio Players & Recorders
The hum from my vip 722k dvr box keeps me awake at night. thank you!!
pwgasson,
Some noise from the receivers is normal as they are constantly updating the guide and checking for any software updates. How loud would you say the hum is, and is it constant or intermittent?
Tommy Faust
DISH Network
Jul 20, 2011 | DISH Network DVR-625 DTV Receiver /...
Rudd model nu. VACC-024JAS. outside unit will not work. A little constant humming. Motor appears to be ok
the constant hum is probably the contactor which may be pulled in on the 24volts check your capacitor that is most common to go out its a canister either oval or round it has wires going in to it please give me a vote and rating
Sep 22, 2010 | Ruud UAMB042 Air Conditioner
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
Constant hum
CHECK THE ALL THE CABLES (RCA) .
i think missing ground sheeld .
or smoothing capacitors are leak.or power output section faulty.
can you poen the cover and check circuit board get wet anyhow,
nuwan
Sep 23, 2008 | Sherwood RD-6500 Receiver
Constant hum after power surge
Try using the OSD menu to Deguass it.
Mar 24, 2008 | Compaq fs740 17" CRT Monitor
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
LG LFC21776ST 21 CF French Door Refer Cab Depth: LFC21776ST Refrigerator Stainless Steel Logo
23 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
