Question about Tech Solution TS-4500 Shredder
TS-4500 not working
Hi, I was shredding some paper (probably about 5 minutes) and then it decided to stop working. First I thought it overheated or something. So I unplugged it and let it cool down for like 4 hours. I plugged it back in but no luck. Any idea? I hardly ever shred, makes me a little sad that I have to buy a new one. Thanks in Advance
  • 2 more comments
  • Anonymous Nov 02, 2007
    My shredder has for the second time stopped working. It will go in reverse but only a few seconds go forward. This is the second one I have owned because the 1st one I returned to Office Max for a new one. I either want my money back or a new one! I am very disappointed in this shredder. This shredder is for home use only.
  • nun25 Dec 07, 2007
    MY SHREDDER STOP WORKING COMPLETELY. IT WILL NOT REVERSE NOR SHREDD AT ALL BUT THE READY LIGHT WILL COME ON.
  • dancermd Jan 13, 2008
    Oiled the cutter as suggested and still does not work. What now?
  • cml234 Feb 18, 2008
    This shredder worked one day and now there is nothing. The green power light is on but it will not go in foward or reverse. I tried plugging it into other outlets, but nothing.
  • 328 Answers
It is a light duty model. Probably jammed the cutter assembly. Will it reverse? Try oiling the cutter. Drop a few drops of vegetable oil at various spots through the cutter.
Posted on Jul 31, 2007
My shredder (lightly used) doesn't seem to be working properly. It sometimes won't start shredding the paper unless I get it started by using reverse first. Then when it does start pulling a sheet...
Does it have a manual with trouble shooting tips or mfr. phone #. Also try a different electrical outlet maybe or unplug power cord & wait a minute or two then replug back in, I don't know that I would use oil as a solution as that may create another issue, you may also try removing top & maybe leftover shredding is stuck up in area where it is not allowing the machine to work at it's best. Look at manual if you have it 1st those types of issues may be common with the machine
Mar 05, 2011 | Tech Solution TS-4500 Shredder
I have read over and over the four-page manual for my TS-4500 shredder and I cannot find information about preventive maintenance such as oiling the mechanism and/or blades. Surely, there must be a means...
Shreddrs do need to be oiled approximately every 30 minutes or so, of continuous use. Any shredder oil will do just fine. Squirt a little shredder oil onto a piece of paper that you wish to shred & feed it through your shredder. That is all you need to do to keep it oiled.
Feb 01, 2011 | Tech Solution TS-4500 Shredder
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
Paper jam. Ready lite comes on but shreder will not start shreding
Common problem with paper shreds blocking the sensors on top and bottom of cutter asm. You may have to remove the top of unit to properly clean. When removing top, be very careful with the short ribbon cable. Lift top slowly and then reach under and disconnect from main board. Once top is off, you can cycle motor by hand and try to remove shreds with needle nose pliers. Of course, disconnect power first.
May 15, 2009 | Tech Solution TS-4500 Shredder
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Dec 09, 2008 | Tech Solution TS-4500 Shredder
Tech Solutions shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Safety Interlock "Switch"
This is not the safety interlock switch. This flat bar keeps shredder paper from backfilling into the cutters. The safety interlock switch is a vertical slot on the body that a tab on the top fits into.
Feb 29, 2008 | Tech Solution TS-4500 Shredder
Shredder Problem
Replace the paper sensor switch
May 27, 2007 | Tech Solution TS-4500 Shredder
My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
217 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
