Question about Pioneer Sx-1300 Stereo Receiver; Integrated Graphic Equalizer 0543
Can anyone tell me the value of Resistor R527 for a Pioneer SX-1300? It's on the power amp portion of the PC board.
The existing one has fried (not sure why). Does that point to another problem? Thanks.
2 Suggested Answers
  • 30 Answers
SOURCE: Pioneer VSX-D412 AMP-ERR message.
The AMP-ERR message in many Pioneer Receivers is caused by some DC in the output. The microprocessor then issues the warning and shuts the unit off. It is definitely not a relay switch. It could be the amplifier power pack, i.e. PAC011A or similar that is faulty or something else. Not easy to repair for the non- experienced DIY.
Good luck
Posted on Apr 24, 2009
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Blowin resistor on my Acoustic Research S112PS
When I put an ohm-meter across it, I get 505-ohms. The color code looks like maybe green, dark brown, brown? Mine is discolored too. Green, brown, brown would be 510ohms. . .so that must be it. The tolerance band is gold, so that's +/-5% so that would explain the 5 ohm variance.
Feb 12, 2009 | Acoustic Research S112PS Subwoofer
Y-SUS board: How to determine if it's fried?
Your solid green "resistor" is probably a fuse and will have an amp rating stamped on it, if you can read it with a magnifying glass. Before you replace that you need to find out what else on the board or somewhere else in the TV is blowing the fuse. Resistors have bands to denote their value unless it is a large power resistor and the value is written on it.
Apr 16, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
When turn on ht-tz212 it shows protect and turnes off again
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Dec 19, 2008 | Audio Players & Recorders
Pioneer SX-950
use a cable tester for the wires that are connecting to the unit and you'll find the faulty wire that is bad.....good luck
Nov 03, 2008 | Pioneer AVIC-S1 GPS Receiver
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Fried resistor, need value for R801
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Nov 08, 2007 | Sylvania 6413TG 13" TV
Jvc sx-dw303
I have exactly the same problem with the JVC SX-DV303. It's like no power can get through. This is posted in the wrong section, i will post in the correct section, see if anyone knows of a solution there! :)
Aug 19, 2007 | Pioneer KEH-1500 CD Changer
Pioneer Sx-1300 Stereo Receiver; Integrated Graphic Equalizer 0543 Logo
27 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
