Question about Vacuums
Samsung 2000w model Sc56bo...how do i empty the bag
How do I load the vacuum bag in the Electrolux power plus 2000w
If your Electrolux vacuum cleaner uses paper bags, the instructions should be printed on the bag.
Dec 03, 2014 | Electrolux Vacuums
Vacuum bags
It would help to know your postal code in order to to find a shop that caries bags for that model. Otherwise you can get them online such as amazon. Samsung Type VP-95 are the bags and should be readily available; also evirocare make a bag for them which is package #211.
Nov 12, 2013 | Samsung Easy 1300 Lightweight Compact...
I have a Vax turbo force 2000w hoover and it doesnt pick up theres hardly any suction and then it cuts out. Any ideas what the problem could be?
Yep,
Your filters are clogged. As a result the motor is straining and overheating, then a thermal cutout operates.
Clean the filters in the top of the vax and if you are ussing a cloth bag empty and wash ot. If a paper bag, replace it.
All should be well
Jun 29, 2011 | Hoover Vacuums
Light is blinking and says "check bag" but bag is properly attached.
Hmmmm, Check bag you say. The manual for this machine shows it as a bagless model with a dirt cup that you empty. Is there an option for this machine that the manual doesn't show?
May 19, 2010 | Hoover U5753-900 WindTunnel Bagless...
Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Sep 28, 2009 | Electrolux Vacuums
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
sounds like you have the plastic bodied canister. the controll valve inside is bad. I usually just disconnect those to avoid future problems. you may want to take the vacuum to a repair shop though becuase they are a pain to get apart and get back in one piece.
Jul 15, 2009 | Electrolux Vacuums
My hoover 2000w keeps stopping. There is no blockage. Please explain.
reddevil6 is correct. This model number is a no-show. It would help to know if this is a canister or an upright, bagged or bagless. Canister models start with the letter "S" and uprights with the letter "U". You will usually find the model number on a silver sticker on the bottom of the unit, or in the case of some uprights, on the lower back of the handle.
Jan 15, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
