Question about IBM Infoprint 1422 Laser Printer
1422 Printing fades with use.
Printing fades as more pages are sent through...Temporary fix is to remove the toner, shake and replace it. This works for a bit. Have use different toners, so it isn't just a used toner.
  • chessyang May 11, 2010
    what's the page count on this unit? original fuses? are you toners remanufactors? oem?
The only reason shaking would help, is if there was low toner or a problem with the toner cartridge, so "yes" it is the Cartridge(s) causing the problem.
Posted on May 01, 2009
Sometimes only prints half a page
make, model? i'm guessing that the toner (printer is of the laser type?) is running low. temporary fix, remove toner cartridge & gently shake to spread (distribute) the powder inside.
Oct 10, 2015 | Office Equipment & Supplies
Printing fades on the page
Does it fade across or down?
Is the printer on a level surface? (important!)
or
Take toner cart out and shake it side to side gently, replace it. Is it any better? (yes indicates low toner)
You may just need a new toner cart or drum
http://printer.konicaminolta.net/drivers/manuals/2300dl/eg_user.pdf
Jul 30, 2014 | Konica Minolta Magicolor Office Equipment...
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Brother hl2142 printing copies out which look faded
The toner could be low.
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 10, 2011 | Brother Office Equipment & Supplies
Fade printing?
Sounds like its running out of toner. To verify this is the issue:
Remove the toner from the printer shake the toner away from clothes and carpet. Some toner may be loose and shake off replace back into printer. If it prints a couple of pages good again then it is the toner getting low.
Mar 09, 2011 | Samsung ML-1640 Monochrome Laser Printer
When printing reports off, all the document does not print to the right of the page. whats the answer to fixing this
Hi
Does print is faded or it prints clear? If faded, just get your cartridge and shake it well to distribute evenly the toner. If prints clear, preview it first before printing and maybe the other print area you want is not included when printing. Just set the print area.
Jan 11, 2011 | HP Laser Jet 1320 Printer
Center
Just remove all the removable parts from your printer including trays, toners, etc.
Shake your print toners so that the toner powder inside is mixed well equally throughout the drum inside.
Replace all the parts back and try printing and may be this should work fine for you.
Please provide back your ratings.
Thanks
Apr 05, 2010 | HP LaserJet 4700 Printer
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
POOR PRINT QUALITY WHEN PRINTING IN BLACK ONLY
may be your new toner can be faulty.you can try this processor first you remove the toner & refix it after shaking.if your problem is not solved then check with new toner again.
Sep 02, 2009 | Samsung CLP 300 Laser Printer
Fading black print
Is the toner orginal?
Try printing a test page and see how that comes out?
Try shaking the toner it might be stuck on one side.
Thanks
Sophia
Jan 06, 2009 | HP Color LaserJet 3500 Printer
IBM Infoprint 1422 Laser Printer Logo
73 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
