Question about Microwave Ovens
My GE unit is totally dead, no lights, display or anything. Power is on to the unit and it is plugged in.
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then
Posted on Jan 07, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave/convection oven JVM1790SK.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's likely a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 27, 2008
  • 112 Answers
SOURCE: Sharp R1420B Totally dead. Power to unit is ok.
Most of these have internal line fuses inside of the casing. Once you remove the housing that covers the top and sides, follow the wires from the cord and they should lead you to the fuse. They are usually on the front rh side looking at it from the front. Be careful, even though unplugged, this unit still stores alot of electriacal energy in the capacitor.
Posted on Oct 27, 2008
  • 108 Answers
SOURCE: GE PROFILE SPACEMAKER P/NO 8114-334-730 MICROWAVE TOTALLY DEAD!
Sorry Seanna, but I have been getting a lot of problems with GE microwaves. You can call customer care at 800-432-2737, but out-of-warranty repairs are very expensive. Sounds like your problem may be door latch circuitry which requires service. If your unit is old, consider replacing it as prices are very reasonable.
Ray
Posted on Dec 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: ge jvm1650 microwave over totally inoperative. No lights
That's usually a blown fuse, cavity TCO or magnetron TCO.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components for testing and possible replacement (such as the cavity TCO) will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Feb 08, 2009
  • 382 Answers
SOURCE: ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Posted on Dec 29, 2009
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
GE xl1800 I have checked both fuses and still no power to the control panel. What is the next failure?
someone needs to follow the voltage into the unit--- The voltage goes to fuse and then to inverter that drives the unit---fyi if unit is not real expensive a repair may not be practical----use some precautions if not familiar with this kind of appliance.
Jun 08, 2012 | GE XL1800 1100 Watts Microwave Oven
Ge advantium 120 powered off after a few minutes
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Ray
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1490 900 Watts
Thanks! I did see that info about the totally dead unit. That's a great troubleshooting guide!
I'm calling it a day for today.
Thanks again!
Nov 01, 2008 | GE JVM1440 Microwave Oven
Oct 26, 2008 | Microwave Ovens
Dead unit
first WAIT sometimes the control board gets wet , it may dry out in a few days and will work again . but while you wait un plug it . a live board thats wet might not last long if powered up ...... if still no good see if the light works . if it does the board is bad if the lights dead too , then theres a fuse inside that may have blown
Jun 13, 2008 | GE JVM1640 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
