Trane fcu is on but no cool air on fan is working. and red llight is blinking
The unit is on but red light keeps blinking and the fan is the only thing thats working
SOURCE: a continous blinking operation light and no indicator light
HAS THE UNIT EVER WORKED?
Posted on Oct 09, 2008
  • 59 Answers
SOURCE: Outside Unit Air Conditioner fan not running
probably a bad fan motor. could be a capacitor
Posted on Apr 25, 2009
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
  • 227 Answers
SOURCE: my outside ac unit is humming and warm..but fan not turning!
Souns like the compressor is running but the cooing fan is not. First you should see if the fan is blocked . Then see If the fan motor is getting power. If the motor is getting power it could be that the motor is bad. If the motor needs a capacitor to start that could also be the problem. Look for a cylinder shaped protrusion on the side of the motor. If these all check out then whatever tells the fan motor to come on is not working. Sorry but I cant help with that. Good luck!!
Posted on Jul 05, 2009
SOURCE: Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Posted on Aug 19, 2009
I have an older trane twe030c140b0air handler and it was workingq fine then today froze. Fan in unit will not run. Sparks from conteoller. Is that the correct name? Unit is 208 thanks
Turn power off to air handler. Jump red and green inside the machine. Turn power on. If fan runs then the problem is likely outside of the machine, that being tstat or tstat wire.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 17, 2017 | Heating & Cooling
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Ps3 red light keeps blinking
Step 1: Check Your Console
One of the biggest causes of the blinking red light problem is placing the console with the fan vents sitting against the floor or up against a wall where air cannot flow freely in and out of the console.
So, start by checking your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean and unobstructed.
Step 2: Test the Hard Drive
Now, find the hard drive on the side of your console and remove it. Wait a few seconds and replace it. In some cases this may fix PS3 red light. If you still see the blinking red light, there is a chance you have more substantial damage inside your unit. It could possibly be a problem with overheating which causes problems with the motherboard, especially if you had your console on the floor or up against a wall.
Step 3: Unplug
The last in-home remedy to fix PS3 red light blinking is to unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating. If it doesn't work, then you have more substantial damage to your console motherboard.
Yet, that doesn't mean the console is useless! Continue on to find a permanent solution to the problem.
If all this doesn't work go through this mannual to have step by step instructions for solving this problem http://www.gamingupholds.com/ps3-repair-guide.aspx
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
My ps3 light blinks red and green i did the fan test and the fan works meaning the power suply too works what's it mien ??? ohh i also reinserted the HDD and the same thing
Does the lights blink red? If so, you have the infamous YLOD, aka. Yellow Light of
Death. This is the number 1 cause of pS3's dying. It is an overheating issue
linked to your CPU and GPU (the processor chips) You will need to find a local PS3
repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive.
The repair process takes about 3 hours.
Jan 17, 2011 | Sony PlayStation 3 40GB System
My playstation 3 wont turn on. The console beeps like normal, then the light quickly turns from red to yellow then immediately back to a blinking red. What does this mean?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
check your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean and unobstructed.find the hard drive on the side of your console and remove it. Wait a few seconds and replace it. In some cases this may fix PS3 red light. If you still see the blinking red light, there is a chance you have more substantial damage inside your unit.Then unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating.
click here to download ps3 repair guide
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
How can I fix my PS3 for free? It won't power on completely and the red light just blinks
checking your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean......
click here to download repair guide
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
My PS3 switched itself off mid game, it now will not stay on and the red light blinks.
The blinking red light is also known as the Red Light of Death (RLOD) similiar to the xbox 360s Red Ring of Dead (RROD)
Step 3: Unplug
Step 4: Check Your Warranty
The next step you can do to fix red light of death is to see if you still have a valid warranty for your gaming console. If you do, then you can contact Sony and mail it in for a fix. Note that this will take at least 6 weeks before you can expect your ps3 back and chances are high you will receive a refurbished unit rather than the one you originally sent in. Also note that Sony will delete the memory from your unit so you will lose everything saved in the console.
If you don't have a valid warranty or you don't want to lose everything saved inside the console, bypass Sony altogether. Without a warranty they charge $150-300 or more and often the unit you receive back will have the same red light of death blinking problem in a short period of time.
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
