Question about Simplicity SE3 Computerized Sewing Machine
My machine will not work. It makes a clunking sound when I try to run it. What is wrong?
It worked fine for quite awhile, but it was not used for awhile and when I went to use it, it would not work. Makes a loud, clunking, grinding sound. I am afraid to keep trying. What could be the problem?
  • Simplicity Master
  • 7,365 Answers
It could be the timing, or it mght need a adjustment, or could have
a loose or broken part,, it would be a good idea to have the
machine serviced
Posted on Jan 08, 2013
Machine making load noise after stop sewing, what is that?
We all know that proper threading makes for happy sewing machines and happy stitchers. And while we emphasize threading with your presser foot up- there are a few other things to keep in mind while threading your machine to make sure your sewing time is happy time!
Have you ever been sewing along on a project, decided to change threads, and all of a sudden you hear a THUNK CLUNK THUNK when you start sewing again?
If not, good for you. But I know that this has happened to a lot of our customers for sure!
Often, this sound comes from not getting your thread in the take-up lever while threading.
If you have a new needle that is the appropriate size/type and your machine is clean, but you start to hear a clunking sound after rethreading, this is the first thing to check. And it's such an easy fix. In fact, I think some people are so surprised when we tell them to simply rethread, because the sound is so terrible they think something is seriously wrong with their machine.
Now, there could be something really wrong with your machine, but the biggest clue that it's a missed take-up lever is that the problem starts suddenly, most of the time after rethreading. (machine was sewing just fine before that).
How do you make sure to thread your take-up lever?
On some machines, it's very easy to see the take up lever, and on others it's hidden behind the machine casing. Here's what you should do to try and ensure success.
-Raise your presser foot!(Full rant here)
-Put your needle in the highest position (use the needle up down button or line up the notch on your handwheel with the casing of your machine- more info here)
-Clear the thread path. Make sure there's no thread wrapped around a spool cap or trapped under your spool.
-Feel it! If your presser foot is up and your needle in the highest position, hold the thread near the spool with your right hand and thread with your left, you'll be able to feel the thread slide into the take-up lever.
-STOP immediately if you hear a THUNKing sound and re-thread. What's happening is that your top thread is not regulated, and it can ball up undereath the feed dogs and cause issues.
-Clean out your bobbin area and re-thread if you think you missed your take up lever.
Aug 25, 2017 | Sewing Machines
Problem with my bobbin case I'm sewing suddenly there clunking, my machine jams, bobbin case flipped 180. took apart, re-adjusted, put everything back and it worked fine, but it keeps happening. Help
Sounds like there are some parts that are worn or broken on your machine. A bobbin, when correctly inserted and latched, should not spin 180 degrees on its own.
Have you tried a brand new needle? Just wondering if it is bent and hitting below the needle plate.
Jul 28, 2016 | Sewing Machines
Wheel won't turn
it's possible that there is a broken or loose part, it would be a good idea to have the sewing machine checked.
Aug 13, 2013 | PfaFF Sewing Machines
Clunking noise from sewing machine
Would need a good look to know whats wrong sorry the bad answer but a sowing machine with clonk ?? could be anything
Jul 05, 2013 | Brother HE-1 Embroidery Machine
Mother board for memory craft 6000
it would be a good idea to have the machine checked to see if
there is something wrong with the motherboard and a sewing
machine repair shop can tell you.
Jan 25, 2013 | Sewing Machines
A "clunking" noise when stitching
some sewing machines have more sounds than others, check to make sure the bobbin is setting securely in the bobbin case,and if that doesn't
solve the noise problem then ,it would be a good idea to have the machine serviced
Dec 31, 2012 | Sewing Machines
My Riccar vaccum suddenly quit working
I have a feeling that you don't have it put together quite right. Open up the bag area and look around the edges for a switch for button that the enclosure depresses. (something like the thing that turns on and off the refrigerator light)
Good luck
Dec 19, 2012 | Sewing Machines
Clunking noise when sewing flannel new machine
try changing the needle
clean under the needle plate for lint, flannel has quite a bit of lint
make sure the bobbin is turned the correct way in the bobbin case
try rethreading the machine top & bobbin
May 06, 2012 | Brother XL3750 Mechanical Sewing Machine
What is wrong with the mach if it misses the stitch on the bottom, it doesn't catch the tread? It doesn't make a clunking sound but doesn't sew.
Could be the needle is in backwards, not pushed all the way up into its housing or blunt. Try changing it first, rethreading machine top and bottom and try again.
If that fails and it is not forming a stitch at all, then the timing could be out and will need servicing.
Mar 27, 2011 | Euro-Pro Shark 9110 Sewing Machine
Computerized brother cs 100 keeps untreading itself while sewing
it is not threading properly
indicates that the needle /hook timing is off a bit or the bobbin thread tension is too tight
Sep 24, 2017 | Brother CS-100-T Computerized Sewing...
Simplicity SE3 Computerized Sewing Machine Logo
94 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
