Question about LG Dryers
TEST CONTROL PANEL ON LG DLEX8377 - LG Dryers
  • LG Master
  • 8,220 Answers
Lg direct drive start button is not work" what's problem in machine
Take off the control panel. There is a little plastic arm behind the start button that may be worn down on the end and may not be making contact with the electronic button underneath.
To access the control panel on the WD14700RD:
  1. Disconnect the unit from power and water
  2. Remove the top: take off two screws at the back, push it backwards one inch and lift it off
  3. Take out the soap tray and remove two screws on the soap tray compartment.
  4. Remove the control panel: push down on the two arms on top of it so that it can pop out, and pull it out at the top and then lift it off the bottom hooks. Pull it out a little from the machine, about an inch.
  5. Remove the front plate from the control panel: there are 7 screws behind it. Rotate the control panel up or down in order to access the screws behind
  6. Now that the front plate of the control panel is loose, identify the arm of the button that has stopped working. Wrap a small amount (2-3 times around) of electrical or plumbers tape on the very end of the plastic arm. Or if there is a nib instead of an arm, a small dab of epoxy resin allowed to harden does the trick.
  7. Refit the control panel and test the button now works.
  8. Reassemble the control panel, top, and turn on water and power.
  9. Test once again.
And that's it! All you need is a screwdriver and some tape. Too easy. Hope the information helps out.
Sep 17, 2016 | LG Washing Machines
My running lights are working just fine no brake lights any suggestions? 1999 Lincoln continental
Brake light switch ? Lighting control module , fuse's ?
The stoplight switch is protected by Fuse 32 (15A). This fuse is hot at all times. With the stoplight switch closed, power is provided to the stoplamps through the lighting control module through Circuits 9 (LG/O) and 5 (O/LB). Ground is provided to the stoplamps through Circuit 57 (BK).
Symptom Chart-Stoplamps
Refer to the Electrical and Vacuum Troubleshooting Manual for connector numbers cited in the pinpoint tests. Use Rotunda 88 Digital Multimeter 105-R0053 or equivalent to perform pinpoint tests.
Symptom Chart-Stoplamps Condition Possible Source Action
  • No Communication With Lighting Control Module
  • Circuitry.
  • Lighting control module.
  • GO to Pinpoint Test BA .
  • Stoplamps Inoperative
  • Open fuse.
  • Circuitry.
You may want to take to a repair shop !
PINPOINT TEST BB: STOPLAMPS INOPERATIVE BB1 TEST STOPLAMPS
  • Press stoplight switch.
  • Check stoplamps and rear high mount lamp.
Are lamps on? Yes No RELEASE switch and make sure that lamps turn off. CHECK Fuse 32 (15A). REPLACE open fuse if open, RESTORE vehicle, RETEST. If fuse is good, GO to BB2 . BB2 TEST STOPLIGHT SWITCH INPUT
  • Connect Rotunda New Generation Star (NGS) Tester 007-00500 or equivalent to data link connector.
  • Enter diagnostic data link.
  • Enter lighting control module.
  • Enter PID/data monitor and record.
  • Select PID: BOO_LCM - Stoplight Switch Status.
  • Hold stoplight switch.
Does data display read ON? Yes No GO to BB5 . GO to BB3 . This is with a factory scan tool , a code reader will not work !
BB3 TEST FOR VOLTAGE AT STOPLIGHT SWITCH
  • Test for voltage at input Circuit 10 (LG/R) to stoplight switch connector C253 .
Is B+ present? Yes No GO to BB4 . SERVICE Circuit 10 (LG/R) feeding stoplight switch. RETEST system. BB4 TEST VOLTAGE OUTPUT AT STOPLIGHT SWITCH
  • Test for voltage at output Circuit 511 (LG) of switch connector C253 .
Is voltage B+ at the switch? Yes No SERVICE Circuit 511 (LG). RETEST system. REPLACE stoplight switch. RETEST system. BB5 TEST POWER TO LIGHTING CONTROL MODULE
  • Disconnect connector C207 from lighting control module.
  • Test for voltage at connector Pin C207 , Circuit 907 (Y/W) and Pin C207 , Circuit 906 (R/O).
Is voltage B+? Yes No GO to BB6 . SERVICE Circuits 906 (R/O) and/or 907 (Y/W). RETEST system. BB6 TEST OUTPUTS
  • Using jumper wires, short Pin C207 , Circuit 907 (Y/W) to Pin C207 , Circuit 9 (LG/O). Using jumper wires, short Pin C207 , Circuit 906 (R/O) to Pin C207 , Circuit 5 (O/LB).
Do stoplamps illuminate? Yes No REPLACE lighting control module. RETEST system. SERVICE Circuits 5 (O/LB) and 9 (LG/O) for open circuit or damaged bulbs. REPLACE open bulbs as necessary. RESTORE vehicle, RETEST. This is Lincoln factory service info !
Jul 04, 2015 | Lincoln Cars & Trucks
Does a dryer have areset button
Generally speaking no. It might be the control board or the power supply or the control panel that is bad. You can take the top off and there should be a set of technician instructions that say what to test.
Jun 18, 2013 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
We were just moved by a moving company and my dryer worked the day before they moved it. Now, my LG DLE7177RM won't power on at all. We had our maintenance come and check the outlet, that's fine, we bought...
Sounds like damage was done to the control panel during the move. You will need a qualified LG tech to test the controls and see if the power button was broken during the move.
Oct 03, 2010 | LG DLE7177 Dryer
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
LG LSC 26905SW control panel for temp, ice,
Replace the control pnl.
There is no way to fix the existing control.
Jan 12, 2010 | LG Refrigerators
Unlock code for LG KP500, free and it would be good if it was'nt BS. I've tried 2945#*# and 2945#*7101# etc. none of them worked, it just said ''please try again'' thx in advance
some cod
Lg old and New
LG Chocolate =2945#*#
lg kf700 =3845#*700#
lg ku250 =26911147#*250#
LG 900 v09e
Citazione:
TEST MENU: 277634#*#
LG 900 v10b
Citazione:
TEST MENU: 082065#*#
LG U970 Shine
Citazione:
TEST MENU: 26911147#*970#
LG L600V
Citazione:
TEST MENU: 63342425#*#
LG KU310
Citazione:
ENGINEER MODE: *72346#96
LG KU800
Citazione:
TEST MENU: 26911147#*#
LG KU830
Citazione:
LG KU950
Citazione:
TEST MENU: 7973845#*#
ENGINEER MODE: 21738#96
LG KU990
Citazione:
TEST MENU: 3845#*990#
ENGINEER MODE: 364663#96
MENU NCK: 2945#*990#
KF310 kF311 reset codes
Test menu: 3845#*310#
for kf311 3845#*311#
engineer mode: 364663#31
menu : 2945#*#
This procedure is for LG CT810.
To RESET your phone back to factory defaults which will erase all current content and revert the device back to original shipped configuration:
1. Turn off your phone,
2. Remove the back panel and take out the battery for about 30 seconds,
3. Put the battery back into the device and replace back panel,
4. YOU MUST PRESS AND HOLD THE FOLLOWING BUTTONS SIMULTANEOUSLY!
a. Left Volume Down Button, AND
b.Right Camera Button, AND Power Button
5.Hold them until you see the green Windows Mobile startup screen and then you can let go,
6. After a few moments, you should see the initial screen caliberation screen,
7.Your device is now RESET/RESTORED to Factory Default (this assumes you have not applied a custom ROM, in which case the reset will simply go back to the defaults of that package)
LG XENON Reset.....Security Solved!!!!
Lg security solved!!!!
Hi there, follow the steps below for LG XENON
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
done it already
Pics Here
LG KE850 ***** security
without and with simcard: 1475369586#*# try this one too: 338464#*# ,then go Reset or restore default.
LG KU800 reset code = 277634#*#
kf311/310 =no sim inside
3845#*310#
KT520 user code reset =338464#*#
Sep 30, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Remote control no response
Have you tested the remote? Get a cheap IR reader card, Radio Shack used to have them, and test the remote. If it's working test or replace the IR detector in the Tv... If both of these are working you'll need a schematic and a logic probe to test the micro or you may need to replace the main cba P/N 33139d3029a
Good Luck!
Bill
Aug 07, 2008 | LG 37LC2D Television
Dryers Logo
46 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
