Question about Hotpoint Dishwashers
Dishwasher wont drain
Keeps overflowing not draining
  • Hotpoint Master
  • 2,292 Answers
If you will open the door on the front of the dishwasher, you should see two small screws going through tabs holding the dishwasher to the countertop. They are in the front, and above the door.
If you will remove those screws, you should be able to pull the dishwasher out about halfway into the room.
Do not pull it farther, because there are 3 important components you want to leave hooked up. The electric wires, the drain hose, and the fill hose.
Remove the front lower panel that hides the bottom of the dishwasher, and you should see a water pump made of plastic maybe the size of your fist, maybe on the right side.
The drain hose should be attached to that pump, as should electric wires. The drain hose goes to the sink drain in most cases
Find a way to catch the water and or sludge that may come out of that hose, and remove the hose from the pump that goes to the sink drain. You may need a pan that holds a quart or more liquid.
See if that hose is clear of being plugged up.
Sometimes too much food left on the dishes can plug up the pump or the hose. Examine the pump to see if it is plugged.
If the hose goes to the garbage disposal, perhaps that is where the plug-up is.
Posted on Jan 08, 2013
SOURCE: Dishwasher drains into sink
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Posted on Feb 25, 2009
  • 93 Answers
SOURCE: hotpoint build in dishwasher will not drain hose not frozen or pl
hello sir you must have a clog at the drain valve or tubing where it enters sink connector alo makesure your drain tubing is not kink thanks from gilles
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Posted on Apr 27, 2009
ginko
  • 19396 Answers
SOURCE: my dishwasher wont drain out
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 17, 2009
  • 57 Answers
SOURCE: kenmore dishwasher 206c1513p007 wont drain
take the cover off the bottom of the dishwasher inside and remover the built up food and turn the wire by hand and even use your hand as a plunger
Posted on Jun 29, 2009
Drain pump wont stop running
Most likely is activated overflow system.
This means water leaks under the dishwasher and is activated drain pump to prevent flooding. The simplest is to lean on either side the dishwasher so if there is water on the floor, that's it. Now you need to identify and repair the leaks. You can not be excluded that a defective triac by driving the drain pump placed on circuit board. It very rarely happens and some brands signals a failure by display or LED diodes .
Dado
Mar 10, 2015 | Asko 24 in. D3250 Built-in Dishwasher
Asko d3250 drain pump wont stop running
Dado
Mar 10, 2015 | Asko Dishwashers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
GVA dishwasher overflow light wont stop flashing
Have you tried unplugging the dishwasher power cord from the outlet, waiting 30 seconds and plugging it back in?
Nov 23, 2013 | Dishwashers
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Overflow draining to the sink
it's supposed to drain out the same drain pipe your sink uses. If it is overflowing into your sink, then your drain pipe is clogged. Your sink probably overflows when your disposal runs too, right? Unclog your pipe and you're good to go.
Jan 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
Apr 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
