Question about Panasonic PT-47WX49 47" Rear Projection Television
Red Gun screwy!!
Two days ago, the red gun went whacky...I went into convergence and it went away. The TV ran fine for two days but today, I turned it on and the same thing it happening. The red is about 2 inches too high on the left side and sweeps down to about two inches too low on the right side. ALso, the top right is too high, but the center looks fine. Can anyone give me some direction at to where to begin troubleshooting this set? Thanks!
    President:
  • 3,130 Answers
You have a typical convergence problem here that happens on just about every tube type projection TV set ever made. There are two STK IC's that will need to be changed. Best thing to do, if you have any soldering experience on printed circuit boards, would be to get the service manual, locate the convergence amp IC's order the correct parts and not any replacement IC's that cost less the 20 bucks, and change the IC's. If you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Posted on Jun 30, 2007
Red convergance is un-adjustable
Yes you can get the repair kit for your model at www.tvrepairworld.com the kits contain the two ICs and the 6 resistors plus the CD with step by step instructions.
Jan 06, 2010 | Panasonic PT-56WX53 53" Rear Projection...
Red convergence problem - Mitsubishi 65
It sounds like your red gun might be close to going, we had the same problem our tv. The red was off and couldnt really be adjusted but the others were alright. We were told that the red gun was nearing the end of its life and it could cost upwards of $1000 to fix, so we just got a new tv. i would suggest having a tv tech come out and look just to make sure, but thats wut it sounds like.
Oct 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sanyo DS35510 35" TV Problem
the red gun or the video driver ic went bad, nothing you can do alone, if the red gun went bad you will need to replace the crt wich is too expensive
Jose
Aug 13, 2008 | Sanyo DS35510 35" TV
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Red gun suddenly went wacko
Red Convergence IC bad.....small circuit board by itself up
above main boards..........replace both IC's for reliability...
STK392-040.........DO NOT USE GENERIC IC'S ! I use only
PANASONIC brand = no re-calls !!
Re-align when repair complete............T.
Jan 28, 2008 | Akai PTH5498 54" Rear Projection...
Hitachi 50UX14B rear projection: Took apart 2 clean, now red is off
What do you mean by covers? do you mean focual lens? did you replace them to there proper place (red to red, green to green, ect..). each has it's own focal legnth and must be placed on the correct gun. did you adjust (accidentaly) the red centering polls?if you did please have a tech readjust them you can end up with convergance amp overload. did you try to converge the lines? if they did not move when adjusting you may have a convergance amp problem. read my motto
Jan 17, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sp43w6hp red gun convergence problem
did you ever do a fluid refill on a crt?.........might be your problem.........
Nov 06, 2007 | Samsung HCM422W 42" Rear Projection...
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
Hi!
as i see in your comment.. you have defective convergence correction amplifier ICs. the RED GREEN and BLUE (RGB) is amplified by the STK ICs. your RED convergence is not working good in the STK ICs! Replace the STK ICs a new one to get back the normal colors. Thanks...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
