Question about Dryers
I need a new belt for an electric 70 series dryer and instructions on installing it
  • Dryers Master
  • 8,220 Answers
I worked on one and made a video which shows how to replace the belt and check various components. PAW PAW's DRYER DIY PAGE
Posted on Jan 07, 2013
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
Mr-Electro
  • 120 Answers
SOURCE: kenmore 70 series electric dryer
probably a broken belt,,
Posted on May 24, 2008
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Posted on Jun 12, 2008
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
My kenmore electric dryer 70 series wont turn. it turns on and heats up but it doesnt spin. what can i do to fix it? i have aparts dryer to use. just need to know what to do. thank you very much
you mayu have a broken belt if you take the cover off you should be able to see if the belt is still on there if not you can get a new one should be pretty cheap.
Nov 12, 2010 | Dryers
How do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Apr 26, 2010 | Kenmore 62602 Electric Dryer
How do I install idler and pulley assembly on a Kenmore 70 Series dryer??
your local appliance parts store would be glad to help u with this . on the back of some belt paks u will find instructions. good luck hope this helps
Nov 17, 2009 | Kenmore 62602 Electric Dryer
Cant figure out how the belt tensoner works to hold the belt tight i have a kenmore 70 series electric dryer
There are 2 slots underneath the motor pulley.
The flat part of the tensioner goues in these slots.
The roller wheel will then be on your left.
With the belt around the drum, run the belt under the wheel and through the tensioner, then over the motor pulley.
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore 70 series electric dryer hums but won't tumble
you do need a new motor.ypu need to take 2 screws out of top where lint filter goes.take top up and their will be 2 screws one on each side take scres out and pull upward and forward and the front panel will come off.you will need to remove belt and tub then you will see motor.you will need to be able to grab back side of motor that attaches to blower and front shaft of motor and turn opposite way to come loose from blower.you will then take back clip off and front clip and unplug motor and pull out.good luck hope instructions helped.
Mar 12, 2009 | Dryers
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
