Question about H&R 1871 INC New England Pardner Pump Shotgun NP1228, 12 Gauge, 28 in VR, 3" Chmbr,
Need magazine cap for pardner pump 12 gauge shotgun
D669090 is the serial # of my Stevens 79 pump gun 30 barrel wanting to know the year it was made.
Have a read of these articles.
I Have Stevens Modle 79 Shotgun And Would Like To Know Rough ...
www.gunvaluesboard.com/i-have-stevens-modle-79-shotgun-and-would-like-to-kno...
  1. Cached
  2. Similar
I have Stevens Modle 79 shotgun and would like to know rough. ... hello,,your stevens model 79 pumpgun would be worth roughly around ... Serial number .
The Gun Digest Book of Exploded Gun Drawings: 975 Isometric Views
https://books.google.ca/books?isbn=0896891410 Harold Murtz - 2005 - ‎Antiques & Collectibles 845 Model 79-T Slide-Action Shotgun 845 Model 99 Lever-Action Rifle 846 ... 99C Lever-Action Rifle 847 Model 99C Series A Lever-Action Rifle (Serial No. ... Rifle 850 SAVAGE/STEVENS Model 89 Lever-Action Rifle 851 Model 94C Series M ...
Stevens 79 Shotgun Manufacture Date? - FirearmsTalk.com
www.firearmstalk.com > ... > Long Guns > General Shotgun Discussion
  1. Cached
May 19, 2011 - Twelve years ago I purchased a Stevens model 79 pump 12 gauge shotgun with a 30" barrel used. The serial # is 0982XXX. Does anyone ...
Stevens 79 Manufacture Date? - Long Range Hunting Online Magazine
www.longrangehunting.com > ... > Shotguns And Shotgunning (NOT Slugs)
  1. Cached
May 26, 2011 - 1 post - ‎1 author Twelve years ago I purchased a second hand Stevens model 79 pump 12 gauge shotgun with a 30" barrel and full choke. The serial # is ...
Nov 23, 2016 | The Optics
I have h&r 20 gauge pump shot gun 1871 wanting to know if there is a slugbarrel for it
H&R Pardner® Pump - H&R 1871
www.hr1871.com/firearms/shotguns/pardnerpump.asp
  1. Cached
  2. Similar
This extremely versatile shotgun has an American walnut stock, ventilated recoil pad, chrome-plated ... 20 Gauge (NP1-206) Order Online From Gallery of Guns.
There are various barrel options including slug barrels.
20 gauge pump shot gun 1871 Google Search
Oct 30, 2016 | Optics
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
How do you load a mossberg 88 maverick 12 gauge shotgun ?
this is the same for your maverick 88.
Sep 14, 2014 | Optics
My Mossberg 500 12 gauge shotgun double feeds cartridges and jams
There should be a catch on the magazine tube of the shotgun, is it ejecting two shells into the chamber when you try to cycle the action? If so check to see that the catch is not damaged. I have the same shotgun and I can take a look at it when I get home.
Nov 23, 2012 | Office Equipment & Supplies
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
I own a Maverick model 88, 12 gauge shotgun. Need plug
the plug is ussaly no more than a wooden dowel that fits inside the spring and is the approx length of the shells put end to end like they would be in the tube
Oct 12, 2009 | Sport & Outdoor - Others
12 gauge shotgun shell converted to metric (ex. 12 gauge + 20mm)
A ordinary 2 3/4 inch 12 guage shell equates to a European 70 mm. a 3 inch Magnum is a 76 mm.
Goof Luck.
Mar 20, 2009 | Omega Juicers OMEGA GUN LOCK 12 GAUGE...
H&R 1871 INC New England Pardner Pump Shotgun NP1228, 12 Gauge, 28 in VR, 3" Chmbr, Logo
120 people viewed this question
Top H&R 1871 INC Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a H&R 1871 INC Optic Expert? Answer questions, earn points and help others
