Question about SmartDisk Verbatim 96867 2 TB External Hard Drive
Pc does not recognize external drive
Old pc windows 7 is OK, when pluged in new windows 8 does not recognize it
  • 7 more comments
  • Vasa Suboni
    Vasa Suboni Jan 09, 2013
    Hi Brian, I did try all the steps, but, Device manager does not want to recognize it. HERE IS THE LETTER FROM VERBATIM Hi Vasa, Thank you for contacting Verbatim Technical Support. We request you to use the hard drive on Win XP,Vista and Win 7 Operating system. The hard drive is not tested on Win 8 but it may or may not work on Win 8 OS. Your Case # 00104040 If you need any further assistance please call us on: 646-537-3411 and we will be happy to assist you. Regards, Verbatim Technical Support. QUESTION__SHOULD I JUNK IT? I appreciate your help, thanks, vasa
  • Vasa Suboni
    NICE, good advertize for Verbatim External Drive
  • Brian Sullivan
    Brian Sullivan Jan 09, 2013
    windows 7 can be an absolute pain with large external and usb hard drives windows 8 im not sure of i have had no problems as yet keep hounding verbatin support im sure someone will eventually resolve your problem keep me posted
  • Vasa Suboni
    Thanks Brian, I will let you know
  • Vasa Suboni
    Vasa Suboni Jan 10, 2013
    The Problem is VERBATIM problem, their product (External 2TB Drive) is not design to recognize windows 8. I got a drive that I cannot use.
  • Brian Sullivan
    Brian Sullivan Jan 10, 2013
    how are you connecting it with usb 2l or sata lead connection ? how long have you had it ? warranty
  • Brian Sullivan
    what sort of computer desktop or laptop ? being such a large hard drive you might need to install a usb 3 card
  • Vasa Suboni
    it's about 1 year old; i believe the warranty is one year. i have new dell inspiron 660 with windows 8 PRO,processor core i 5, 8GB of memory and 2TB drive; has usb 2 & 3 instaled. The problem i belive is the driver.
  • Brian Sullivan
    Brian Sullivan Jan 11, 2013
    Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-fre... Windows XP/Vista/7/8 Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
  • SmartDisk Master
  • 27,725 Answers
External hard drives are plug-and-play devices used to store music, video and data files.
Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Posted on Jan 08, 2013
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Imation Model D353fue not recognized by MACBook Pro
It is a "plug-and-play" USB-device, and *should* be recognized, if the hardware inside the case is in working order. So, exercise that "warranty" to get it replaced.
Try connecting it to a Windows PC (XP/Vista/7/8), to see if Windows will recognize it.
Feb 02, 2013 | Imation Model D353fue External Usb 3.5"...
Upgraded from windows 7 to windows 8 ,now storage device not showing.
Have you tried to shut down the computer, unplug the usd external drive, reboot the computer, plug in the USB external HDD the should apply the driver. That said, Have you tried a Thumb Drive or any other USB device in the USB ports? It's a common problem when upgrading a OS that Hardware issues popup. Open the Device Manager, Is your USB controller working? Enabled? Any other devices in error? Unknown devices? Use the Win 7 drivers for your computer found on the computer manufacturer's website. Change the compatibility on the driver for Win 8.
Jan 11, 2013 | Western Digital 1TB WD ELEMENTS USB...
Got a Sumvision External 2.5 Hard drive for over a year now and today i pluged it in as normal and got the following error messages - using windows 7 also tried it in XP and it doesnt recongise the hard...
Hook up that external hard drive to another computer that you know for sure the USB ports work properly. If you still get the same error message or the drive is not recognized then that means the hard drive is bad.
If the hard drive is recognized properly and you can access the files then that means its an issue with the operating system.
May 14, 2011 | Computers & Internet
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I have a iprodrive external hard drive and my laptop does not reconize it any more. the last time i used it i did not disconnect properly. is there a way to reset it
Here a step by step guide i found as i surf the net last week. Read along.
  1. Step 1 Log in to your computer as the administrator.
  2. Step 2 Install the external drive software from the CD that comes with your external hard drive.
  3. Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  4. Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  5. Step 5 Go to the "My Computer" icon and double-click on it.
  6. Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  7. Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  8. Step 8 Choose "quick format" from the format options section from the next pop-up box.
  9. Step 9 Click the "Start" button.
  10. Step 10 Click the "OK" button in the Format warning box.
  11. Step 11 Click the "OK" button in the "format complete box" to finish the process.
Should you have any questions regarding this post feel free to post it here.
  • Step 2 Install the external drive software from the CD that comes with your external hard drive.
  • Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  • Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  • Step 5 Go to the "My Computer" icon and double-click on it.
  • Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  • Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  • Step 8 Choose "quick format" from the format options section from the next pop-up box.
  • Step 9 Click the "Start" button.
  • Step 10 Click the "OK" button in the Format warning box.
  • Step 11 Click the "OK" button in the "format complete box" to finish the process.
  • Read more: How to Reset an External Hard Drive | eHow.com http://www.ehow.com/how_4840145_reset-external-hard-drive.html#ixzz0YYmAf0Ra
    Jul 24, 2010 | Computers & Internet
    External HDD no longer recognized by new win7 PC
    Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
    Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
    SmartDisk Verbatim 96867 2 TB External Hard Drive Logo
    131 people viewed this question
    Top SmartDisk Computers & Internet Experts
    Sunday Ojelabi
    Sunday Ojelabi
     Ian Kayhan
    Ian Kayhan
    Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
