Question about ASUS A52F-XE2 Notebook
Asus a52f stuck on asus logo screen
Notebook wont start up into windows and function keys wont work
  • 537 Answers
SOURCE: How to Dis assemble ASUS A8E NOTEBOOK? some keys
Check this forum link:
http://forum.notebookreview.com/showthread.php?t=209881
Posted on Sep 23, 2009
  • 10406 Answers
SOURCE: Our Asus notebook, model US0F, manual is very
On the bottom-left of the keyboard is the BLUE-coloured 'FN' key. Hold the FN key down (just as you would hold hold the SHIFT key) and touch one of the other blue-labelled keys, and release the FN key.
Posted on Apr 05, 2010
  • 8909 Answers
SOURCE: Hi! My asus notebook wont
It would apear that you have a boot sector error. The main system apears to be working. Ctr+Alt+Del will not work because windows is not loaded.
With your rescue disc in the DVD drive, just before it boots up repeadedly press F8 until you get the secondary menu that will let you choose Safe Mode, Restore, Rescue etc. and choose Safe Mode. If it boots all is OK and when it has finished the system should have repaired itself. If it doesn't choose restore, this will try to restore the system. If that doesn't work, Rescue is the only other option.
Hope that helps.
Posted on Mar 29, 2011
  • 81 Answers
SOURCE: asus notebook/which function keys do
Fn+F2 WLAN is usually the default.
Posted on May 24, 2011
  • 102 Answers
SOURCE: I press f8 when starting
You have to tap F8 Repeatedly right after the initial splash screen goes away. Then it will come up with a menu for you to choose Safe Mode.
Posted on Jun 30, 2011
Asus a52f usb not working
check the drivers are in
Apr 21, 2014 | ASUS A52F-XE2 Notebook
My asus A52F sound is too low
Right click on your speaker icon, click on volume mixer, check the slider, should be right up, also check recording and playback, if not working, you can troubleshoot sound problems, you can try this out.
Feb 07, 2013 | ASUS A52F-XE2 Notebook
Few keya are not working
To determine if the keyboard or the keyboard controller is faulty, plug an USB keyboard into the USB port on your laptop. If all the keys are OK on the USB keyboard then the laptop's keyboard is faulty and needs to be replaced. If the USB keyboard also malfunctions then the keyboard controller chip on the motherboard is faulty, then the motherboard needs to be replaced, but this may not be a cost effective solution.
A replacement keyboard for your model laptop maybe available from this WEB site.Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Sep 07, 2012 | ASUS A52f-xe6 A52f Ci5/2.66 15.6 4gb 500gb...
A52F keyboard problems
Looks like your keyboard has been hijacked. Turn your computer off and boot up in Safe Mode. When you hit the power button to turn the computer on immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. Once safe mode is up things will look different to you. The icons will be bigger and the screen will be darker, that's normal.
If this started happening to you recently say only a day or two ago then lets try doing a System Restore to a date and time before it started happening. Click Start/Programs/Accessories/System Tools/System Restore. When System Restore pops up look for an option that will allow you to pick additional restore points than the one you see. You want to pick a date and time that was before your keyboard started acting crazy.
Let it run to completion then try typing again.
Don't worry, System Restore does not destroy your data, documents, music, pictures, videos, (programs (unless you added a program after the restore point you selected)). System Recovery destroys everything and sets your system back to when you first purchased it.
Mar 22, 2012 | ASUS A52F-X3 PC Notebook
How can i log in safe mode on asus a52f
I have enclosed a link to most of the windows OS since they not all will get you into safe mode the same way...
http://www.computerhope.com/issues/chsafe.htm#03a
If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting... Thank you for using FIXYA! Best regards,
Junior
Sep 15, 2011 | ASUS A52F-XT1 Notebook
When I connect my ASUS monitor to my Dell laptop the ASUS monitor displays nothing instead it says "No Signal"
Hi
You do not say if your laptop screen is working or not or why you want to use an external monitor.
Assuming the laptop has no fault and boots properly, to send the laptop image to an external monitor, once you have booted into Windows, press and hold the Fn (function) key bottom left of your keyboard, near the Windows Logo key, then simultaneouly press the Function key (above the numbers) with the image of 2 monitors, 1 dark, 1 bright (often the F4, F5 or F6 key).
If the laptop's screen is faulty and the above procedure does not work, there may be damage to the graphics card which will probably require specialist repair.
I hope this helps.
Aug 27, 2011 | ASUS MW221U LCD Monitor
I press f8 when starting but unable to get into safe mode. I have windows 7 OS on an ASUS A52F.
Jun 30, 2011 | ASUS A52F-XT1R 15.6" Laptop Computer PC...
When I type on my ASUS U50A notebook, the cursor jumps ahead and behind, especially when I'm tying the letter "o". How do I fix it?
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem.
We are committed to supply a variety of laptop parts for fulfilling your needs.
<a href="Asus'>http://www.laptopparttips.info/2012/09/09/asus-n53sv-keyboard/">Asus N53SV Keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-n53sv-keyboard-replace.html">Asus N53SV Laptop Keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus G60jx White Keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g60jx-keyboard-replacement.html">asus g60jx black keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g60jx-cpu-fan-replacement.html">asus g60jx laptop fan</a>,
<a href="replace'>http://www.laptopparttips.info/2012/09/09/how-to-replace-fan/">replace cpu cooling fan</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus g53 keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&q=asus+a52f&cid=0">Asus A52f laptop Part</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-lcd-cable-replacement.html">asus a52f lcd cable</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-keyboard-replace.html">asus a52f keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-battery-replacement.html">asus a52f battery</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-cpu-fan-replcement.html">asus a52f laptop fan</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-white-keyboard-replace.html">asus a52 keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53-keyboard-replace.html">asus k53 keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53-lcd-hinges-replacement.html">asus k53 lcd hinges</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53s-cpu-fan-replacement.html">asus k53s cpu fan</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53s-lcd-cable-replacment.html">asus k53s lcd cable</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-u50-keyboard-replace.html">asus u50f Keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g73jw-g73s-keyboard-replace.html">asus g73 black keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">asus g73 white keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-u50f-u50a-keyboard-replace.html">asus u50a keyboard</a>
Mar 24, 2010 | ASUS Computers & Internet
Doesn't start
hi i got biostar g31d-m7 motherboard dual core cpu 1 gb ram 500gb hard it wont boot just stucks in windows logo screen and cant even reinstall windows its just stucks in the booting logo
Oct 06, 2009 | Intel Desktop Board D845WN Motherboard
New laptop wont start stuck on asus screen
This just happened to me today. My notebook is the same model. I was logging into a game and all of a sudden it blue screened. After that every time I restarted it would go to the Asus logo screen (I think that's what is referred to as the splash screen but could be wrong). No keys worked. Nothing I could do. So, I called Asus and they had me unplug the power, take out the battery and hold down the power button for 10 seconds. Now it's fine. Apparently it just needed to be reset. I hope that helps. Good luck.
Jun 18, 2009 | ASUS MyPal A639 Pocket PC
ASUS A52F-XE2 Notebook Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
