My HP PSC 1610 paper feed is malfunctioning. When something is sent to printer the message states Out of Paper but there is paper. The rollers don't engage the paper.
    Problem Solver:
  • 7 Answers
Shut down your computer. Pull the plug from the printer to the computer.Wait two minutes. Start the computer and re insert the printer cables. It should recycle and work. f not re-post question.
Posted on Jan 14, 2013
  • Ross McOrmond Jan 15, 2013
    I tried your suggestion with the same result. The spin wheel in the back seems ok. You can hear all the rollers working but it doesn't pick up the paper
SOURCE: HP PSC 1510 printer malfunction
Open the rear cover and clean the roller with clean water. Worked for me.
Posted on Mar 08, 2008
yooperbud
  • 8637 Answers
SOURCE: My HP 1610 thinks there's a paper jam - when there isnt one.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: HP psc 1300 printer
this printer does not print on photo paper...read the specs online about it....prints on regular stock paper but NOT photo paper....i have the same prob.....need to buy a photo paper compatable printer.
Posted on Feb 23, 2009
  • 3567 Answers
SOURCE: My HP PSC 1210 will not feed the paper through
Try removing the paper and replacing it with a heavier paper > pull out the 20# copy paper and replace it with 24# bond or 60# offset. ( The 24# and 60# are the same weight just different finishes on the surface ). Assuming your paper tray is one that slides in and out, close they tray firmly. Turn the printer off, wait 10 seconds then turn it back on. If the problem is still there, look VERY closely at the edges of the feed tray / compartment. There will be a very thin wire that the paper will depress when it is loaded into the feeder. If that wire gets bent the paper may not reach it to depress it. The printer does not sense any paper if this happens. Bend the wire outward so the paper can depress the sensor switch. Hope this helps.
Posted on Mar 14, 2009
SOURCE: won't feed paper
I had the same problem it was not feeding paper, and was giving the out of paper msg, I checked and the feed roller ( small black one in contact with paper) was not rotating, Also when the back cover is removed the roller also did not rotate. I took apart the printer and found that a white gear with the encoder disc (clear film with printed lines) on the central shaft was slighty broken, The shaft is knurled but is a poor design. I had to drill through the gear and the shaft to fit a pin to be able to fully secure the gear to the shaft. Kevin
Posted on Jun 09, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 - Keep getting paper jam error with no paper jam.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jams at every feed - even after I clear the jam...
Make sure all paper has been removed from the paper path.
Even a small scrap will cause a jam.
The other thing you may want to do is clean the paper rollers with alcohol.
This cleans any paper dust that has gathered on the rollers, and allows better paper movement.
Sep 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Out of paper message, won't feed paper
The feed roller was turning but the paper wasn't moving and so I kept getting an "out of paper message." The paper was actually getting caught on a small black piece in the back of the printer. I removed the black piece and the paper start to feed fine.
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.
May 20, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
Won't feed paper
empty out thr paper supply, check the paper feed area for debris, blow out area with compressed air (Computer Duster), fan paper carefully and re install.
retest machine
Ed
May 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Mar 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
80 people viewed this question
k24674
