Question about OKI Office Equipment & Supplies
OKI C5850 - the top edge of the paper keeps folding, top right, top left and sometimes top middle
  • Maggie Cottier Jan 08, 2013
    tried all of that, printer and also duplex unit has been cleaned etc.
  • Maggie Cottier Jan 09, 2013
    When printing duplex, some of the pages have the top right hand turned over, some have the top left corner turned over, occasionally the middle of the top of the page is turned over. it is as though somebody has turned the top of the page to keep a place in a book. only a small corner and when in the middle of the top of the page it is across about 3 inches. I hope that helps. something is clearly happening when the top of the page is being picked up by the printer.
4 Suggested Answers
jonb3838
  • 237 Answers
SOURCE: PAPER EDGE FOLDS OVER TOP LEFT WHEN COMING OUT OF THE PRINTER
the reason why i ask that because if the fold looks like its been pressed then its before the fuser but if its loose than its after. And thats how we can determine where it begins
Posted on Feb 12, 2009
  • 43 Answers
SOURCE: hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Posted on Jun 18, 2009
  • 122 Answers
SOURCE: Paper is coming out scrunched (folded) and
Make sure the printer is clear of any paper jams and don't load the tray full of paper, load it 75% full but not 100%.
Posted on Feb 28, 2011
In 5020i while using the ADF papers are geting folding at right corner only in orginal not in the copy
There may be a staple, paper clip or other obstruction in the paper path. Get a flashlight and look carefully at the left side - top and bottom of the ADF. I've also had problems with the guide located to the left of the glass being damaged and catching the edge of the paper in the curved part.
Jan 27, 2011 | Canon imageRUNNER 5020 Copier
How to install adding machine tape to a radioshack EC-3033
Here is the link to the instruction book for that calculator. It describes how to install the paper into the machine. The only thing I could recommend different is to fold the lead edge of the paper to a 45 degree angle /| instead of the straight edge the book is recommending. Sometimes there is a small blockage in the feed path and the angled fold will get the lead edge passed it enough for the feed rollers to catch the paper. The blockage usually feeds out with when the edge of the paper clears the rollers. I would try it by the book first then try the folded edge. The only other option would be a middle fold /\ in case the blockage is on the edge you folded from in the first attempt
Link to EC-30333 book
http://support.radioshack.com/support_radios/doc46/46048.htm
Hope that helps
Jun 12, 2010 | Casio FR-2650A Calculator
Feb 12, 2009 | HP LaserJet 4350 Printer
L7780 won't print on edge of paper
it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Black fades left to right
change the toner
check paper path
check the fusser unit
Mar 22, 2008 | OKI C5150n Led Printer
Where do i put the paper into to replace a new roll
There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
Feb 04, 2008 | Sharp EL-1701C Calculator
My printer folds top lefthand corner intermittently? why?
Do you run labels through the unit? If so, ther is probably a little bit of the glue or label that is inside the feed asm. Hard to find it. Have you tried to open the top door when the paper has fed just under the toner cartridge to see if the bent edge begins at that point. Did the problem appear right after the new maintenance kit? Do you still have the old fuser asm? Reinstall the old fuser and see if problem goes away.
Jul 31, 2007 | HP LaserJet 4250n Printer
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
