Question about Manitowoc MAN-CVD2075 Condenser Unit Remote Air Cooled Models QR DUAL0 QD DUAL2C and QY DUAL4C
My mantowac ice machine qd0452a makes ice once and will not make anymore says bin switch what do i do
The magnet on the door makes contact but says bin switch to make reverse
    Novelist:
    Champion:
  • Manitowoc Expert
  • 373 Answers
Replace bin switch if switch is bad if switch is good then replace board.
Posted on Oct 10, 2014
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
Ice bridge to thick
there is a timer, adjusted by seconds, first make sure the condenser coil located under the ice bin is clean. the harvest is initiated by suction pressure once the pressure switch makes contact the time delay will time out initiating the harvest. you can fine tune the bridge with the time delay.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Mr freeze ice machine parts ice sensorthe unit never starts just shuts off
It believes that the bin is full. You will need to clean the sensors. Should be a couple of eyes under where the ice drops. Or if it has a door, check to make sure the magnet is still in the door.
Mar 26, 2014 | EdgeStar Kitchen Appliances - Others
Have a mantowac 150 Model # BD0152A, plug it in and it begins the freeze cycle and will go thru the harvest cycle once or twice then it kicks off and everything melts. I can reset it and it will start the...
It is going off on a safety limit. Either taking too long to harvest, or too long to make ice. When you switch on, the pcb will flash once or twice. The manual , or usually a printed sheet inside the lid, will tell you which limit has been exceeded and what the likely causes are.
Sep 20, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
This is a QD0452A ice maker it will not cycle properly, water will not shut off, have to watch cycle and manually shut off water ,let ice dump, then turn water back on.
It can be a variety of problems. The door bin switch should turn off the unit when it senses that the door is open (bin full of ice). It is a curtain that opens out to release the ice.
Next it could be the water inlet solenoid, it energizes to allow water in for the ice making process. If it stays constantly on then that would be your problem.
Look at the control board light indicators and you'll know what cycle it is on. These parts are energized and seek help if needed.
Sep 16, 2013 | Manitowoc SY0454A S Series Ice Maker...
Why is my Viking freezer not making ice?
I would suspect that the sensor used to measure if the bin is faulty. They usually use a small probe or a magnet on the ice maker door, if one is dirty or the door is not closed properley the machine may think the bin is full and decide not to make ice. I would look for a sticking door or dirty probe.
Sep 07, 2012 | Viking Refrigerators
WHAT SHOULD GAS PRESSURES RUN ON MANTOWAC BD0452A
i just want to know the what kind of refrigerant gas is using for bd0452a manitowac ice machine
Jun 25, 2012 | Manitowoc B Style Ice Storage Bin 22 Ice...
We have a commerical manitiwoc ice machine that after the bin fills up it cuts off and has to be reset. After resetting it fills up again and a blinking light comes on telling me that something is wrong....
Manitowac uses a plastic deflector which has a magnet located on the bottom. When the machine drops the ice the deflector opens breaking the circuit to the bin switch. This would indicate "Bin Full" condition. As the ice is used the deflector closes and the magnet comes in touch with the bin switch.
Most likely the bin switch needs replacement.
Feb 22, 2011 | Freezers
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc MAN-CVD2075 Condenser Unit Remote Air Cooled Models QR DUAL0 QD DUAL2C and QY DUAL4C Logo
180 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
mike cooper
Dan Webster
Dan Webster
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
