Question about Freezers
My dometic Rm7401L is not working on 12v when mobile
The 12 volts comming into the control board is going up and down. It sounds like a start relay problem
2 Suggested Answers
joemxavier
  • 342 Answers
SOURCE: need new control panel for dometic rm7401l
You have to contact the service center immediately.
Posted on Jun 11, 2010
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
Freezer fan on compressor off
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Jul 13, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Need new control panel for dometic rm7401l
May 14, 2010 | Freezers
Freezer temperature v
This sounds like your motherboard,computer or control board(they call it different things in different models) is bad. It is responsible for the fan speed and timing of the defrost cycle. To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Freezers
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Mar 14, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Freezer stop running after black out
your relay to compressor is bad.you can replace relay or try a 3-n-1 hard to start to replace your relay overload and capacitor.very simple repair.call your nearest appliance store and give model # for your relay and overload or call and see about the hard to start.
Mar 13, 2009 | Freezers
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool AFG 7080 Freezer - Relay noises
It sure sounds like you have a problem with the board. It may just be a dry joint or a faulty component. Normally one would replace the board.
Nov 01, 2007 | Freezers
Freezers Logo
29 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
