Question about Sony nwz-b173 usb walkman mp3 player 4gb [red]
Nwz-b173 I plug it in the usb, it charges but when it is fully charged i unpluget and it wont start or do anything.note every time i put it in the usb conection it starts to charge ,even thow it was fully charged a minute ago.
ThaMp3Doctor
  • 8596 Answers
SOURCE: it wont charge
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
SOURCE: Sony NWZ-A816 won't charge
I had the same problem my mp3 would not charge.To fix connect the mp3 to your computer with the usb cable, go to Device manger open up portable devices you should see a small yellow triangle (this is telling you some thing is wrong) right click over walkman and choose up date driver .windows will use hardware wizard on the net to fix the driver.This worked for me i hope it fixes your problem
Posted on Oct 30, 2008
SOURCE: My sony nwz-a828 won't turn on
I just bought mine yesterday and after turning it off whilst the bluetooth was disconnecting it would not turn on again. Then I pushed the reset button on the back and it has started working again.
Posted on May 16, 2009
DamonJones
SOURCE: My Sony Walkman NWZ-E435F wont turn on at all even when plugged in with my USB
I had the same problem. For at least a week. Try pressing the reset button. The reset button won't delete your music, videos, pictures, etc. Just resets your system. If that does not work then i don't know what else to tell you.
Posted on May 21, 2009
  • 10 Answers
SOURCE: cant charge sony walkman nwz-s615f via computer
buy a new charger
Posted on Sep 10, 2009
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
USB device does not work
Purchase a usb power plug to plug your device into the wall if it charges then your computer just needs to re install the device driver
Aug 29, 2009 | Sony NWZ-A816 Digital Media Player
My player charges but does nothing else
Try a different USB cable instead. Most likely a pin in the USB cable your are using is faulty and because of that your computer can't detect your player as the pin required for your computer to detect it is faulty. You can take a look at http://mympx.org for other users who have similar problems as well.
Jul 14, 2009 | Sony NWZ-A816 Digital Media Player
Fully Charged Sony NWZ-E436F Doesn't Turn On
did anyone ever get back to you on this? I'm having the same problems.
Jun 28, 2009 | Sony NWZ-E436F MP3 Player
My fully charge sony media player NWZ-E435F will not turn on
Hey...Just remove the Battery for 2mins, reload and Power ON again...It may work
-sai
May 21, 2009 | Sony Walkman NWZ-B135 MP3 Player
May 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
My sony NWZ-E436F will not turn on!
on the back of the mp3 it should have a reset button on it. press it and try to turn it on.
( it wont erase anything)
Apr 22, 2009 | Sony NWZ-E436F MP3 Player
Wont turn on or off
my firend had the same problem, he lost his charger, so he brought it over to my house, and it seems that it took about 7 minutes for the "e.m.h.i.m." screen to get off and actually start charging, so just plug it in and go do something to amuse yourself for about a half hour and see if anything changed from when you plugged it in, if you still need help, email me at videogamedominationmaster@yahoo.com
Nov 11, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sony nwz-b173 usb walkman mp3 player 4gb [red] Logo
122 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
