SOURCE: Cooker Hood problem
check the printed circuit board behind the switches - maybe when bulb blew it took out some of the track. usually repairable by soldering in a link over the damaged track. have you checked the fuse as well?
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: kenmore elite ranghood (series# 550) not working
unplug the unit and unscrew the bulbs. put 2 new in if they still dont work then you may have fried the control. there are usually no fuses between the control and light/fan. well i never saw a fuse between the 2.
SOURCE: Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
SOURCE: Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Good Afternoon friend, thanks for your post!
From what you have described your Electrolux hood is working properly but the lights are not coming on. I understand that you heard a bang when the old ones went out it could be possible that your receptacle is bad or wire has shorted. I would suggest having a technician out to properly diagnosis your hood. They have the appropriate tools and knowledge needed to pinpoint the reason your lights are not working properly. Good luck. -Matt
