Question about Montgomery Ward Microwave Ovens
Model 8286 Stopped opeating during a convection cooking time.....now it will do nothing.
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: I recently bought a microwave/convection
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Posted on Aug 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You should be able to get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jun 08, 2009
heatman101
  • 43501 Answers
SOURCE: My Viking microwave convection oven model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Electroluc convection microwave stopped working while cooking
Hi - From what you have described it sounds like the microwave possibly has a wiring failure or faulty control panel or magnetron. I would suggest contacting a professional that accurately diagnose and repair the unit
Oct 01, 2012 | Electrolux EMS2487X Convection Microwave...
During cooking last night - (about 20 seconds into cooking a piece of fish on a microwave safe plate), it sparked, banged and quit working. Control panel is out. Can this be fixed, or should I purchase a...
I worked for a place that repairs appliances and rule of thumb is if a microwave sparks dont bother trying to fix it just replace it.Microwaves work with so many watts sparks could mean a resister is shot witch could be very dangerous and if it stopped functioning thats probably the case.
Jul 17, 2011 | Whirlpool MH1160XS Convection/Microwave...
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
Apr 23, 2011 | Microwave Ovens
R9H84B Sharp Microwave Convection from 6-6-1997, power stopped and turntable stopped. Light works and sounds like the power is working but nothing gets hot.
Is this the unit with the door that swings down like a conventional oven?? I think it is. This sounds like a door switch but could be a magnetron or cook relay on the control PCB.
Sep 11, 2009 | Sharp R-9H84B Microwave Oven
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Sharp 1874- Door seems to "jar open" and oven stops
if you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Feb 20, 2009 | Sharp R-1874 Convection/Microwave Oven
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time....
Aug 12, 2008 | GE Microwave Ovens
Microwave Ovens Logo
26 people viewed this question
Top Montgomery Ward Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
robert
Are you a Montgomery Ward Microwave Oven Expert? Answer questions, earn points and help others
