Question about Kodak Scanmate i1120 - Document scanner - Duplex - 8.5 in x 34 in
I have a Kodak Scanmate i1120 scanner. I cannot get the scanner properly installed to scan PDF files and I cannot get the Smart touch button feature to work at all.
I have tried installing and reinstalling and have not made any progress. I keep getting an error message that says "ERROR WK1117-WIBKEY.SYS is not installed"
  • 415 Answers
SOURCE: My computer had a meltdown and I had to reinstall
follow the link below for xp drivers
http://www.kodak.com/global/en/service/downloads/dln_ekn030179.jhtml?pq-path=6638/6639
Mark
Posted on May 07, 2009
reitann
  • 214 Answers
SOURCE: kodak easyshare software error 1624x17x4252799284x
You need to run the clear utility before installing the software www.kodak.com/go/clear, then download the latest version at www.kodak.com/go/edl
Posted on Dec 23, 2009
  • 5416 Answers
SOURCE: I just bought A Kodak
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Posted on Jan 06, 2011
davidmamian
  • 543 Answers
SOURCE: I want to add the
install program finereader, or pdf editor
Posted on Jun 02, 2011
SOURCE: Trying to set-up a Kodak
You need to uninstall old driver then reinstall new driver from below link. Click here Click on above link download driver for your os uninstall old driver and all usb drivers from device manager then install driver. Make sure there is not any incompatible usb drivers in computer. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jun 21, 2011
After I start, what causes error E12?
Hello
You can check the following:
1. The second scan image interface cable
2. The second scan image
Which is usually the interface cable fault
Jun 11, 2015 | Kodak Scanmate I1120 Scanner
Software disc for i940 scanner
The driver and smart touch are on the web the other bundled software your out of luck
SCANMATE i940 Scanner Support Drivers Downloads Kodak Alaris Kodak...
Jun 23, 2014 | Kodak Office Equipment & Supplies
Kodak scan mate i1120 not connecting to outlook
Don't use outlook to acquire images. Use Smart Touch. Within Smart Touch you can call a program like Outlook to open and accept a scanned document. Read the user guide for Smart Touch. http://graphics.kodak.com/docimaging/us/en/support_center/index.htm
Mar 06, 2014 | Kodak ScanMate i1120 Flatbed Scanner
Mac kodak scanmate i1120
I am assuming you are inquiring about MAC drivers for the i1120? Not happening.
Jan 24, 2014 | Kodak ScanMate i1120 Flatbed Scanner
Red light keeps flashing
Install the most recent driver: http://graphics.kodak.com/docimaging/us/en/support_center/index.htm
Ensure the scanner is NOT plugged in to a USB 3 port (usually blue or has the letters "SS" (Super Speed)). If so, turn off, plug in to a USB 2, power it back up with the most current drivers.
Dec 05, 2013 | Kodak ScanMate i1120 Flatbed Scanner
Trying to set-up a Kodak Scanmate i1120 Scanner on a notebook with Windows 7 Professional 64 bit Downloaded and installed "InstallSoftware_i1100v1100_v1.11.exe" When I try to run "Scan...
Jun 21, 2011 | Kodak ScanMate i1120 Flatbed Scanner
How to install kodak i 1220 flatbed.
1st You download Scanner Driver. Kodak Scanner Driver After this install the Scanner driver in the system.
Installation of Scanner Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or scanner device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 03, 2010 | Kodak ScanMate i1120 Flatbed Scanner
Problems with Kodak i1220 Smart Touch software
Go into C:\programdata\ and remove the kds_kodak folder. It may ask you to skip files it can't delete. Just click skip for all of them (probably around 15 files). Then reboot your computer and you should be able to scan.
Jan 23, 2010 | Kodak i1220 Pass-Through Scanner
Kodak Smart touch button not working
I had same problem with Kodak s1220 scanner. Smart button didn't invoke the oem program in Windows 7 64 bit. It started the windows program which wasn't as slick as the oem. I un-installed and re-installed programs in all kinds of orders to no avail. The updates didn't address the issue. I finally started digging in the various folders in the update package and found a directory called "Button app" it had a install setup program and a file called "killKSS". After that it worked! Sweet. Now if I can only charge kodak for my time.
Aug 20, 2009 | Kodak ScanMate i1120 Flatbed Scanner
Kodak Scanmate i1120 - Document scanner - Duplex - 8.5 in x 34 in Logo
143 people viewed this question
Top Kodak Computers & Internet Experts
gaucherre
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kodak Computer and Internet Expert? Answer questions, earn points and help others
