Question about Graff Plumbing
How do i reapir kitchen faucet vintage 4120 by graff
Faucet leaks at the top around handle
  • 2976 Answers
SOURCE: one handle kitchen faucet leaks
There are "o" rings in the area where it is leaking. You can get them at almost every hardware chain. Clean everything well with scotchbrite ant put silicon grease on before you put it back together.
Posted on Feb 21, 2009
  • 659 Answers
SOURCE: Moen One-Handle Kitchen Faucet Leak - Hot Only
http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
Posted on Apr 11, 2009
  • 260 Answers
SOURCE: repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Posted on Apr 23, 2009
SOURCE: 533-50 kitchen faucet leaks above base mount at
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    My Graff kitchen faucet just started leaking slowly. What needs to be replaced.
    it depends on the type . if new enough it probably has cartridge if old it probably has washers. this is one site I found http://www.chicagofaucetshoppe.com/Graff_Faucet_Parts_s/8628.htm
    Jan 22, 2015 | Graff Plumbing
    Remove the handle from graff kitchen prescot faucet- stuck
    you may have to use a little force gently pry under the handle be extremely careful not to break handle i usually take a piece of wood to put up against faucet or whatever and then tap faucet with hammer then start prying back side with a screwdriver or small breaker bar use your hand to try to wiggle the handle
    Aug 30, 2014 | Graff Plumbing
    K-12177 leaking around top
    If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
    He has a very extensive list of repair parts for faucets.
    Rod
    US Parts Center
    Jan 24, 2013 | Kohler K-12177-G Fairfax single-control...
    Leaking around the top, tightened the handle, leaking down the sides to the base from top ring
    hi . there should be an o-ring or a piece of dirt under the top . cut water off and take handle off clean and put back together it should be fine. have a good day.
    Feb 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
    Jan 01, 2010 | American Standard Kitchen Faucet 6310 020...
    I have a leaking Delta single handle kitchen faucet, The leak is between the faucet and the knob at the top. I have replaced the ball, 2 springs, two seals, the cap with a notch in it washer for that and...
    I may be able to help you. Some faucets are made with the option to have a base or to mount directly to the counter.The bigger washer might be the one that seals the faucet to the counter The leak out of the top of the faucet is probably caused from the plastic nut with the grooves in the top of it not being tight enough. The repair kit should have came with a tool that has a allen wrench on one end and two prongs on the other.Use the pronged end to tighten the plastic nut ,If the other parts where put in correctly this should cure your problem. If the faucet continues to leak you can get a pamplet that will give you instructions from a rep at the plumbing supply or on line in one of the sights for Delta Faucets.
    Dec 13, 2009 | Delta 2402 Classic Single Handle Kitchen...
    Trying to take apart kitchen sink to repair leak.
    you may have to force them a little, I believe there are some plumb putty under the faucet and the handle. if you are unlucky, there may be some caulking under the handle and the foucet insteand of plumber's putty.
    Apr 19, 2009 | Plumbing
    Plumbing Logo
    218 people viewed this question
    Top Graff Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Graff Plumbing Expert? Answer questions, earn points and help others
