256CHENAL TV KIT SERVICE MUNU
TUNIG LOK
4x4 not engaging 97 chevy 305 high/low light flashes but wont engage in either
Try putting it in nutrual / park engage 4 wheel drive then place the truck in reverse and drive backwards for about 5' sometimes helps if that dont its probably the motor that engages the 4 wheel drive on the axle
Nov 19, 2014 | Chevrolet Cars & Trucks
How do i channl search my tv without a remote?
depends.....whats the type of tv and model? some tvs are fully remote controlled but if ya tv has a menu button press menu then press ok then select the options displayed by using the down arrowed button press ok go to search/tunig select auto tuning/search press ok it will select all channels automatically and store them press menu to exit
Jul 08, 2013 | Televison & Video
I have a 2005 32in philips tv that I need to auto program the channels, how do I do that?
Hello
What is the exact model number to your Philips 32 inch TV? Each and every model will differ in tunig proceedings. If you provide the model number to your Tv, [which can be noted at its bac cover] I'll send a solution to your TVs tuneing problem.
Mar 10, 2012 | Philips Televison & Video
I can't unlock my phone into my munu
You directed this question at me, but I claim no expertise on this subject. FixYa suggests I inform you that I cannot help you. According to FixYa, this will put your question into the general pool for other experts to answer.
Jan 01, 2012 | Cell Phones
My new qlx-3 extension kit comes with a plastic bag with 2- aluminum collars and a couple of allen screws&wrench.What is this for?No,no instructions!
The aluminum collars are PROBABLY safety stops to prevent the other clamps from slipping down too far if they work loose. I would expect they go on the vertical tubes aboove the X clamps.
Mar 31, 2011 | Quik-Lok Quik Lok QLX3 Keyboard...
How do i add channels on my sansui television, I can't receive above channel 15..... they are all fuzzy
check your cabel canaction is not proper or bad singnel
if ok than
Auto chennal serch to fix your all ch. ok?
if not then
problum is in side of tv . tunig voltage is not proper 33v so pls check with nr tech. fix this problum essly.
Oct 30, 2009 | Sansui DTV2760 27" TV
My old zenith (probably early 90s) only gets up to channel 48 when there are more channels provided by my cable service. I have used the autosearch, and thats what number it goes to.
[1] use LG exteanel setup box chenal convater 90 to 200 ch avalabel in market .
[2] use inside of tv extra chenal convater pcb. PHLIPS.
[3] change complet new tv chasis with new latest function and all new facilety
EXP.
UOC Technologey chasis
NTSC /PAL /SCAME / AUTO Multi Colour System
Auto Search tunig
A/v 1 -2 -3 Stereo.
A.v Out facility
DVD Comonent input
surround sound mode
1300w pmpo woofer System
on timer /off timer /clock /sleep timer facilety
calender
5 pictur mode
Curtain Effect.
all facilety Avalabel in TOSIBA /SANYO chesis
pls Cont. your Nr.tv techicien
Oct 30, 2009 | Zenith C27A24T 27" TV
2857DB Toshiba TV
turn it off and back on again in menu if that doesnt work change some settings back and forth
Jul 24, 2008 | Toshiba 28N33 28" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
