Question about Bosch Vacuums
Bex bissell powerwash de luxe removal of floor nozzle window to clean
Carpet shampooer
CompuGuy44
  • 432 Answers
SOURCE: carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Posted on Jul 15, 2007
reddevil6
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
  • 207 Answers
SOURCE: Removing clear cover to clean Bissell Power Steamer Pro
Post your email address and I'll send you pictures of how it comes off. Make sure the tank is removed and the handle is back, so press on the pedal to release the handle. The reason if feels like it's going to break, it's because there's a seal all around the clear cover to ensure suction and water stay within that area. Pull it straight up, with force.
Posted on Apr 30, 2009
SOURCE: Bissell Proheat Turbo carpet shampooer/ stopped working
wont put out solution on floor
Posted on Dec 18, 2009
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfhjdhg
Posted on Sep 30, 2010
New bex bissel wont release water onto carpet
Hey Margart! I understand how frustrating it is to have no spray when trying to use a machine.
We have a terrific list of FAQ's on our website to assist you. Here's a quick link: http://www.bissell.com/faqs/?cid=ccsocial
Feb 09, 2013 | Vacuums
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My carpet cleaner bissell pro heat wont extract the water from the carpet
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Nov 22, 2010 | Bissell 8910 ProHeat Clear View Upright...
My Bissel ProHeat carpet shampooer is not spraying to the floor. I have checked the hoses best I can and they appear to be clear, no clogs. The nozzles don't looked clogged either. The above floor hose...
I had the same problem I took out then nozzles and cleaned them out . works well now . I run the shampooer with out the nozzles to clear the lines .
Jan 21, 2018 | Bissell 9200 Upright Vacuum
I require instructions on how to use the Bissell Powerwash
Contact the Bissell services in your country - most of the Bissell sites (www.bissell.com) for example have Adobe user instructions of which you can download.
Apr 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to clean
I have found this so i think this answers my question.
Question         How do I remove the clear floor nozzle window on my machine?     shim.gif     Answer         Before starting, please be sure the machine is not plugged in and the machine handle is reclined.
To remove the clear floor nozzle, first detach the phillips head screws located at the base of the clear floor nozzle. Then, remove the tank in tank assembly. Next, remove the rectangular gasket at the top of the nozzle, and pull the clear floor nozzle forward to remove the tabs from the notches. This clear floor nozzle is removable so you may be able to access this area and clean.
When putting the clear floor nozzle back in place, please be sure the tabs at the TOP of the nozzle are properly inserted into the notches provided. If you do not have the tabs in place properly, you may have a problem with the machine's suction.
Rotate the window down into place, replace the screws, and replace the rectangular gasket.
If you would like additional assistance, please contact BISSELL Consumer Services at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET or email us by clicking on the Email BISSELL tab at the top of this page.
Reminder: When you have completed the deep cleaning process, it is recommended to return the SmartMix dial to "Water Only" prior to storing the machine.     shim.gif     How well did this
Oct 10, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
47 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
