Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Light on stove won't go off when stove is off
Light on our jenn-Air ceramic surface stove won't go off when stove is off, and the burner dosn't get hot either, but the knob light is on at all times as if that burner is on, but not hot.
  • RBullard Feb 07, 2009
    Same problem. Light is on indicating that the burner is on, but it's turned "off" and it will not turn on or get hot at all. The knob turning also doesn't feel right, so I'm guessing the knob mechanism itself is shot. I'm pretty mechanical and would take the unit apart and replace it myself if I could get the part.
  • schamm Mar 25, 2009
    My dual back left burner won't turn on & the light won't go off. Is it the dual burner or the dual infinite switch?
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
huuum
  • 750 Answers
SOURCE: Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
Posted on Dec 12, 2008
  • 222 Answers
SOURCE: Front double burner not working on Jenn Air
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
Posted on Jul 04, 2009
Krazytech
  • 725 Answers
SOURCE: how do i replace my burner on my jenn air ceramic
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Posted on Sep 19, 2009
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
Why burner on light on stove wont come off
After stove is turned off, the light stays on if burner still warm. If the burner never came on, then it needs to be replaced with new one.
Apr 26, 2014 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Cooktop igniter sparks but gas will not light
hello there. i can help you.
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician
Jun 04, 2009 | Jenn-Air JGC8536 Gas Cooktop
Discoloration of cooking surface (darkened) on Bosch stove
I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Hello
Welcome to Fixya
My name is Huum,
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Knob not working and some burners not heating
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
578 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
