Question about Reddy Heater-30-55,000 BTU Variable
Built in thermostat and fuels
Built in thermostat shuts off correctly, but i have to unplug and replug to get a refire.
I have a 5 to 8 year old reddy heater 55000 btu, can I use diesel in this heater like the newer models and what changes would be needed?
  • 92 Answers
Diesel fuel requirs a hotter spark for ignition and burns pretty dirty, better off with K1 kerosene. You could change the ignition system to a mutifuel but it's not cheap and may not mount to your current houseing but would still work. As for restarting it is one of two things: the hight heat limit control or most likely teh CAD flame sensor, both of which you can get from Mr. Heater for less than 3 bucks each. the mount for the limit control is different but you can simply remount it to your heater mount. Same thing with the flme sensor, the wires are different but you can splice the to your wire harness and it will be fine. there is no wrong way to hook them up so don't worry about ground or hot.
Posted on Jan 23, 2009
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
Ice on the back wall; temperature went from 58 degrees to 34 degrees; had to shut off regrigerator
hi,
Wine cabinets work off of cycle defrost, so in order to built frost your temperature sensors are not working properly. I would look for corrosion on or in connections to be the fault or problem. Sensors report information to control unit and thats there only job. Its the control unit that dictates function. Look for corrosion to be the problem, clean connection and seal with RTV when connection a corrected.
Good Luck
Sep 10, 2011 | Transtherm Ermitage Wine Cooler
I have a unit that has built in thermostat. When
my ready heater pro115 model numberr115 keeps shutting off
Dec 20, 2009 | Reddy R115DT Oil Filled Utility Heater
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
Heater will not refire
make sure its not a problem with the low voltage wiring to the stat. the other problem with not firing i either pressure switch not making or the flame sensor is dirty/thermal coupler (not sure which one it has)
Nov 21, 2009 | Dyna-Glo Heating & Cooling
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Koolspace wine cooler
I have the Vintage Keeper Odyssey. I had the same thing the other day. Unit is 7 years old. Vintage Keeper web-site suggested to unscrew the control box and remove. (The box with the "Set" and Up and Down arrows. Unplug the wiring and sensor on the back and then plug back in. Plug in the unit and text. It took my "AL" away.
Unit doesn't cool very well. A coolant leak may be my problem. I was looking for solutions other than buying a new refrigeration unit.
Jun 07, 2008 | Vintage Keeper Koolspace chillR Cooling...
Reddy Heater-30-55,000 BTU Variable Logo
78 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
