Question about Compaq Presario 5000 PC Desktop
Ihave Simpledrive 500GB external hard drive but now all of a sudden my PC does not recognize it when I go to my computer and look for it
  • Compaq Master
  • 27,725 Answers
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement.
Incompatible USB Port Problems W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts b> SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter b> If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. Enable Drive Letter View b> Click the "Start" button and choose "Control Panel" from the start menu. Click "Folder Options" and navigate to the "View" tab. Scroll down and place a mark next to "Show drive letters," then click "OK." b> Configuring Drive Manager b> Click the "Start" button to launch the start menu. Right-click "Computer" and choose "Manage" from the menu. Click "Storage" in the menu on the right side to extend the section. Click "Disk Management" under the "Storage" header. This will show you a list of drives and removable storage on your computer. It will also report the status of the drives, such as "Healthy." If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter. Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths." Click the "Change" button, then choose a drive letter from the drop-down menu. Select a letter that is near to the end of the alphabet to prevent drive overlap issues. Click "OK" to allow the changes to take place. You should now see the removable storage listed with your other drives on the "My Computer" screen. SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible b> If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing. Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted. b> Replacing a Defective Hard Drive b> You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services. Hope this helps.
Posted on Jan 07, 2013
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
My computer will not recognize the external harddrive so I can't access it
Connect it to a different computer. If it is not recognized, then it has a problem.
If it is recognized, then your computer has a problem recognizing it.
Apr 10, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Cannot get computer to recognize my simpletech external hard drive. I have windows 7
A problem I commonly have is if the external drive is plugged in to a non powered usb hub the unit does not have enough power and will not be recognised, ensure it is plugged directly into the pc tower or if you have a laptop try an alternate usb port as some may not be powered.
Mar 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Not recognized
Make sure that the connectors are inserted properly. Try another cable or see if it mounts on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive suddenly disconnects a Reconects again....
You may have a power supply that is defective or is failing. Try another power supply, 12V, 2A, center pin positive.
Jan 24, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
My computer doesn't recognize the SimpleDrive...
Hello jajogeglez,
You may need to use another USB device, be it another flash drive to narrow down if it's just your Simpledrive that's causing this.
You can also update the USB devices under your Device Manger using the CD driver for your motherboard.
Hope this helps.
Nov 20, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
500gb St ex hard drive suddenly disconnects when still plugged in
please try to check your external hard drive if theres a problem aside on the cord connecting to pc...
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Compaq Presario 5000 PC Desktop Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
