Ricoh 3228c sc 902 - Office Equipment & Supplies
4 Suggested Answers
goalie39
  • 469 Answers
SOURCE: how to recharge some users of the ricoh af 3228C in the office?
Most Modern copiers have an access code system built in, this works in two ways, first it elimnates unauthorized copying as the machine is essentially locked if you do not have a code.
Second, It allows you to track the copies made by each code. By assigning each dept or individual with an acess code you can now track the number of copies each has made.
You will likely have to have the service tech come in to set up the feature and adminitrator functions. Once this is done you will have better control of your machine.
I have seen in larger operations a 20-25% reduction in copies once the codes are in place.
If the built in controller does not have enough access codes or features there are aftermarker products available.
Hope this is of some help
Ed
Posted on Apr 17, 2009
  • 224 Answers
SOURCE: please solve this problem Ricoh SC 902
and?
Posted on Mar 31, 2010
  • 109 Answers
SOURCE: please solve this problem Ricoh 7650 Code SC 902,
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
Posted on Apr 03, 2010
Ricoh aficio 3228c error sc 873
Thats a hard drive error. Initialize SP5-832-008 or replace the HDD! Most machines use a simple IDE HDD. Just open the machine at the back, youll see the HDD
Jul 18, 2014 | Ricoh Aficio Office Equipment & Supplies
We connected 2 computers to our Ricoh 3228c nd now it prints everything in code, how do we fix this?
make sure you are using the right print driver and if using a mac need postscript to print
Jan 03, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Ghost image ricoh 3245c
No can do, if you are referring Norton Ghost. Ghost it only for OS on computers. Printers have chips with instructions.
Here are the drivers in case you need them.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c35_45/c35_45en.htm
Oct 25, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Please solve this problem Ricoh 7650 Code SC 902, 302 and 322
Definition [B’]
Possible Causes
• LDB defective
• SICU defective
Mar 31, 2010 | Ricoh Aficio 1035 Copier
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
k24674
jasbo
jasbo
