Question about Gestetner DSc224 Copier
Where is the place of drum in the copier and how opened it
How to clear a code
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200
Sir/Mam
If available
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
How to reset the drum on a Brother 7840
Remove old drum from the unit.
Remove toner and install in the new drum.
Place Drum Back in the machine, leave cover open.
With the cover door open Hold Clear/Back button (about 5 sec.) until the Lcd reads Replace/Reset Drum? yes? no?
Press 1 for yes and close cover.
The machine will cycle and restart, once it says ready the counter has been reset to 100%
Feb 18, 2011 | Brother MFC 7840W Printer
Sharp ARC-172M how the drums get out?
open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum out towards you....done.
Apr 21, 2009 | Sharp AR-BC260 Color Copier
I am getting Call Service 7410:00 32266 on FS-3900DN Kyocera Laser Printer.
You have pulled the drum unit out of position possably after changing the waist toner ? Open the back cover, open the frunt cover and remove the developer unit, the full unit not just the toner, open the side cover where the waist toner bottle is and push the drum unit back into place until it clicks, put the dev unit back in place and close everything reboot the machine
Apr 18, 2009 | Kyocera FS-3900DN Laser Printer
Doc. Cover Open displayed
That usually means some sensor giving you trouble.
This is what brother recomends:
How do I clear the message Cover Open or Please Close Cover from the display?
The message Cover Open or Pls Close Cover may appear if the front cover
for the drum was not closed securely. Verify the cover is closed
securely by pressing the cover release button located in the front of
the unit below the Output Tray Support Flap and open the front cover.
Close the cover until it clicks into place.
If the message continues to appear on the display verify the drum and
toner assembly is installed correctly by following the steps listed
below:
1. Press the cover release button located in the front of the unit and
2. Remove the drum unit and toner cartridge from the unit by lifting it
up and out. Place it on a drop cloth or disposable paper to avoid
scattering toner.
3. Hold down the blue lock lever located on the right side of the drum
and lift the toner cartridge out of the drum unit.
4. Reinstall the toner cartridge into the drum unit by inserting it in
the drum until it clicks into place
5. Reinstall the drum unit into the unit. Make sure it is securely in
place.
6. Close the cover until it clicks into place
If that doesn't fix it, I guess you will have to talk to their support people.
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
Error message "Waste Toner Full Replace The Drum" which was replaced approximately one month ago.
Open the left cover,remove the drum.you will see on the drum unit there is plastic plugs that you can remove,remove them and remove the waste toner in the dustbin.put the plugs back and insert the drum in it's place.
Dec 04, 2008 | Canon imageRUNNER 1023iF Black and White...
Changed drum cartridge DR-520 in Brother 8065DN Instructions say to hold go button and there is no go button that I can see. with new drum in place it is still giving drum low mesg to...
Hi Kathleen,
  1. open the front cover
  2. press the clear/back key
  3. press 1 to reset
  4. close the front cover, pressing firmly on each side until they click into place.
Really hope this helps and if so please mark as fixya...
Oct 02, 2008 | Brother Office Equipment & Supplies
The drum cartridge
Open the front door. Remove the toner cartridge and the drum is on the upper right. You have to open the right side door to safely remove it. but just a little squeeze on the lever and it slides out, slide the new one in until you feel it latch ( click) into place.
Mar 21, 2008 | Sharp AL 1631 Copier
23 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
