Question about Kettler TX1 Treadmill with FREE INSIDE Delivery! Treadmill
High speed and error 91 and treadmill stop - Kettler TX1 Treadmill with FREE INSIDE Delivery! Treadmill
    Top Expert:
  • Kettler Master
  • 12,223 Answers
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it
If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached.
God bless you
Posted on Jan 07, 2013
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Proform Treadmill 785 E suddenly stops during highs speed workout
Use 2000W converter instead of 750W because you are using your treadmill on its full power on high speed. 750W converter is not capable of handling its full load resulting the machine malfunctioning. Your treadmill 785E have 2.25 CHP motor, 2.25 CHP is equal to 1677.824712W and 20-Amp minimum Ac outlet is required for your treadmill in order to function in full capacity. Download user's manual on: https://www.sportsmith.net/images/product_support/ProForm/PFTL785081%20-%20PROFORM%20I%20SERIES%20785%20E%20TREADMILL/PFTL78508.1-274823.pdf See Horse Power to Watts Converter on: http://www.rapidtables.com/convert/power/hp-to-watt.htm
Apr 16, 2017 | Proform Exercise & Fitness
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
Client run on treadmill then suddenly its stop and display an error speed, then 5 seconds treadmill belt moves again and moves faster whats the problem of that?
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Feb 25, 2011 | Life Fitness 9100 Next Generation...
Manual to trouble shoot/run diognostics
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 30, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Speed sensor error
Your speed sensor may have failed and cause this condition Call Accell Fitness Of North America @ 1-888-388-6887 they are the Tunturi Distributors
May 04, 2010 | Tunturi Programmable Treadmill with...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Elevation has gone too high. foot rollers are hitting front plate
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
Kettler TX1 Treadmill  with FREE INSIDE Delivery! Treadmill Logo
676 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven Brandon
Steven Brandon
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
