Question about Lincoln Ranger 8 8000 Watt Kohler Gas Engine Driven Welder/generator Job Ready
Have to jump start lincoln ranger 8 welder from car to start it won't stay running unless i leave jumper cables attached
CarlGehrke
  • 169 Answers
SOURCE: lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Posted on Feb 23, 2009
  • 5 Answers
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Posted on May 03, 2009
mamicheddy
  • 79 Answers
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
Posted on May 07, 2009
  • 1348 Answers
SOURCE: 1996 lincoln towncar. No a/c compressor engagement unless jumped
the control unit is no good.i had a similar situation with a 98 tracker,and installed a switch to give it a ground for the compressor relay that comes from the a/c computer module.
it works good and goes on and off with the a/c switch.
Posted on Jul 18, 2009
  • 24 Answers
SOURCE: ENGINE REMOVAL ON A LINCOLN PORTABLE WELDER, WITH
The collar is a slip ring, you remove the engine and rotor together and then remove the rotor from the engine.
Posted on Sep 18, 2009
Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
Jan 25, 2013 | Lincoln Ranger 8 8000 Watt Kohler Gas...
2003 Elantra-Car ran fine until my son's door was not complelety shut and battery died, jumped car, but once the jumper cables were removed the car dies. Thinking it was an electrical issue, check
some alternators need battery voltage to stay running and after killing a battery if may not recover and you will need to replace it then i would check the fuses its posible that when first jumped the cable where on backwards
Aug 07, 2012 | Hyundai Motor 2003 Elantra
98 Buick Regal won't run unless hooked for a jump.
you may have a bad ground, or the ignition switch needs to be replaced.
Jul 28, 2012 | 1998 Buick Regal
Haven't run the bike in a while, won't start. I have run the battery down trying. Where do I hook up to "jump start" from a (non running I am told) car?
Personally, unless I was stranded somewhere, I wouldn't jump start the bike. I'd rather recharge the battery and try to start the engine again. But, you may wish to find out why the engine is not starting rather than continue to run down the battery or take a chance of damaging electronic components with a voltage spike. You didn't tell me what year and model the bike was nor whether it's carbureted or fuel injected. If's it's been sitting for an extended period of time, the fuel system may be gummed up due to the fuel evaporating and leaving the gummy residue to stop up the fuel passageways. But, if you still want to jump start the engine, connect the jumper cable directly to the battery in the bike, positive side first to positive post of the battery. Connect the negative from the car's frame or engine to the bikes engine or frame last. This prevents a spark and the possibility of the battery blowing up your face. I've had it happen before and it ain't fun.
Good Luck
Steve
Sep 12, 2011 | Harley Davidson XLH Sportster 883...
Suburban won't start, bought a new battery but does no thing, when jump started it stays running until it is shut off and will not start again
If you can jump start it and it stays running....I am assuming that you connect the Jumper Cable Ground to something other than your battery. If so, Your negative battery cable is suspect. Check both ends for ANY corrosion or loose connections.
Aug 18, 2011 | Chevrolet 1500 Cars & Trucks
I hace a Ranger 305 D - we run an air compressor off of the welder but t will not run now it is like it is only putting out on one leg of the plug?
Look at the fuel filter, it should have a access panel on the side. It should have a clear plastic bulb so you can see how dirty it is. It needs to be 2/3rds full of fuel, if not it won't get enough fuel flow. Also do a plug change and Clean air filter. A little trick is to pull the choke out a little and see if it runs better, if so its a restricted fuel problem. Check these simple items before hiring a pro.
Jul 27, 2011 | Lincoln Electric Ranger 305D K1727-2...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
I have a kohler engine on my ranger 8 welder and i can get it to run for a few seconds then it quits or if i keep putting gas in the carb it will stay running .
sounds like filter/line blockage....check all lines and clear them of any contamination...maybe some dirty fuel or water in fuel has been added into the storage tank.
Jul 23, 2010 | Lincoln Electric Ranger 305D K1727-2...
Lincoln Ranger 8 8000 Watt Kohler Gas Engine Driven Welder/generator Job Ready Logo
48 people viewed this question
Top Lincoln Electrical Supplies Experts
 Kenneth
Kenneth
John Trevino
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
