Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Fridge not cooling
No ice build up, compressor kicks on and off in seconds,fan on rear of fridge is running and compressor is hot to the touch
  • 1 more comment
  • Anonymous Jan 21, 2009
    I moved my refrigerator on it's side it will run fine for one cycle then the comprsor clicks on for a couple of seconds and makes a clicking sound . If I unpluge it for a couple of hours it will work for a cycle
  • lewdeb487 Jan 23, 2009
    compressor is locked up !!!
    replaced fridge
    Novelist:
  • 161 Answers
Check the coolant pressure, you could have a leak. Sounds like everything else is working.
Posted on Jan 20, 2009
  • Ron Buice
    Ron Buice Jan 23, 2009
    I would guess all the coolant leaked out which caused it to lock up.
  • Ron Buice
    If that were my Ref, I would have done the same thing.
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
Fan running compressor not kicking on. canister feels really hot.
check that both wires to compressor are connected, trace them back to solinoid, , if the compressor isnot humming u only have 1 leg of power or it is bad
May 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
The center of the fridge between the freezer and fridge is so hot you cant touch it whats wrong should I call a repair person ? thank you for any help
HI, this is a sign the fridge isn't cooling proper. Check and see if there is frost building up on the rear panel of the freezer. Check and see if the evaporator or the condensor fan motors are running. Check and see if the compressor is running.
Pleasae let me know if I can assist you fyrther.
Vic
May 21, 2009 | Samsung RS2630WW Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Amana side by side not cooling
sounds like the start relay on the compressor is bad. take the model number and make to the parts hopuse and have them get you the start relay for your refrigerator. the relay is on the compressor underneith the black cover on the side of the compressor. shut off power and take a screw driver and remove the clip that holds the cover on and you will see the relay. good luck and thanmks for using FixYa
Jan 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frig is warming while freezer is staying cold.
No, A compressor will get hot for about three reasons.
Low refridgerant.
Lack of airflow, (maybe due to very dirty coils or bad condensor coil fan on modes with a fan)
Or high amp draw. (which would mean you have a bad compressor)
Its more common to be one of the first two, especially low refridgerant.
Dec 05, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
175 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
