Question about ASUS Computers & Internet
I have black and white lines running down the screen after I connected it to internet. How do I get rid?
I connected to a public internet system in the university and immediately got got black and white vertical lines running down the screen. I need to get rid of them. the computer seems to work fine other than I can't see part of the screen.
  • 54 Answers
Could be a lose cable, Check the cables connecting to the monitor (screen) and the to PC.
Also, made sure your phone or any other electronic device(s) aren't in close proximity to the screen. They sometimes cause interference.
Posted on Jan 07, 2013
Joed911
  • 4338 Answers
SOURCE: vertical lines on my laptop screen
Bad LCD, was it bumped or dropped?
Inexpensive replacement LCD at :
http://www.smartmicrousa.com/
I have used them for years, GREAT customer service.
Please remember to rate all users who assist you for free :)
Posted on Sep 30, 2008
antiochpc
  • 1314 Answers
SOURCE: Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Posted on Dec 26, 2008
Geekman
  • 32281 Answers
SOURCE: Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 06, 2009
Geekman
  • 32281 Answers
SOURCE: white screen with vertical lines, can't do anything
Can you bootup in Safe Mode?
Press F8 when you bootup.
Then select LAST KNOWN GOOD CONFIGURATION. then check the Device Manager to see if the Video driver is OK and enabled. If OK then shut down and bootup again to see if it boots up normally.
If this doesn't work select SAFE MODE instead of Last Known ......
When Windows starts then select a Restore Point prior to the installation of the driver update and when it boots up again with luck it will be OK. The graphic card update maybe causing the problem.
Posted on Sep 22, 2009
SOURCE: HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Posted on Dec 08, 2009
I have a TH-PX60U that has a black line going down the front of the screen. It goes from black, then back to regular color. The black line keeps coming back. How can I get rid of the black line??
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 08, 2015 | Televison & Video
I have a X4270 fax machine. Whenever i send a fax the recipient says there is a black line running down the left side of the page. I changed ink cartridges but it did not help. Can it be fixed?
The X4270 has a pretty straightforward scan path. If you follow the instuctions on this link, you'll find that you can clean the white roller and scan lens with a lint free cloth and water. It will get rid of the mark....unless you've managed to do something ugly like run a staple through the machine (I did that on a laser and scored the drum....that sucked).
Carl
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.htmlhttp://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html
Feb 18, 2011 | Lexmark Office Equipment & Supplies
White line appears in the middle of the screen
please describe the issue better cause it doesn't make sense..are you saying that your screen background is black no matter of the picture you choose??or that the image of the monitor is just showing a black screen??in the case I sescribed ..if the operation system seams to work but you can not insert any pictures anymore on wallpaper and it is black ..and a genuine advantage program is inserted a banner in the tray system ..(right ) ..this is a case that yous windows is not genuine and the warrning was placed after you check it on a installation ...to get rid of it ...just make a search in the start for a file named..WgaLogon.dll ..and after you lcate it ...rename in by changing a letter in th emiddle (ex: WgaLogTon)..and restart the computer ..after this the functions will be right back ..insert another walpaper and go on ..
If you are talking about the image being just a white line in the middle and the rest is black like it is shut down..than the issue is caused by a condenser burned on the image board..you should have it checked and changed..
Jun 01, 2010 | Dell E551 15" CRT Monitor
I turn it on. It beeps twice loudly and goes to a
Possible Virus and Malware
There is a good chance that you have a virus or malware that is keeping those programs from opening. It does not matter these days what security you have if the door to the web is opened. At the end of this are two links to programs that you should load up and run. The first is MalwareBytes Ant-Malware Tool, the other is Avast Anti-Virus 4.8, install these two and let them perform scans.
Run MalwareBytes first and perform a quick scan, when it finishes, it will ask you to post the results, when it does delete everything it finds.
Run Avast and install it, when it asks, go ahead and schedule a pre-boot scan of your entire system. This should get rid of most problems….
http://www.filehippo.com/download_malwarebytes_anti_malware/
http://www.filehippo.com/download_avast_antivirus/
Oct 30, 2009 | Acer Aspire 1642WLMi Notebook
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
DNS timeout error
Fundenmentals guys.
Type into the browser http://217.146.186.51
This happens to be yahoo ip address. If this works then you have issues with the DNS settings on your network. If not see item 2 below;
Check that via start/Run/cmd - this should take you to a black and white text screen.
type 'ipconfig /all' this will show the connections.
If you have more than one. It's wise to only have one currently connected.
Either Wireless or Ethernet. At the bottom of the list of numbers.
You should see 'DNS Servers' entry. Type 'PING ' then the IP address.
Normally 192.168.0.1 (Might be different so check!), If you get no reply then that's your answer.
Try changing the DNS settings via 'My Network Places/ View My Networks/' Highlight the Connected Network.
Then right click, select Propertise.
Then under 'This connection uses the following items' scroll down to the TCP/IP.
Select it. Then select 'Propertise' At the bottom. Obtain DNS server address.
Select Use the following. Then type the following Public DNS IP address into the first box. 66.93.87.2 and then the one that you found using IPCONFIG /ALL in the second.
This then will lookup the IP address for the URL's that you type into the browser. By asking the Public DNS server first. This is then unrelated to the way that you talk to the internet. (DSL/Corp etc)
Select 'OK' until you return to the Desktop. Open the browser and it should work. But the window system may need a restart for the settings to take effect. Depends on what OS is running.
Item 2:
If it does not then you have issues with you actual internet connection.
Type 'tracert 217.146.186.51' then hit enter.
This will then show the route that the system is taking to get to the website.
If it shows the yahoo.com at the end your fine. Otherwise, it will pinpoint where the system is stopping.
If, it works then the issue is with the browser. Here is the Firefox address to download a better browser! - type into browser http://66.93.87.2 download!
Now, for those sorry chaps that stop, without reaching the end!!
Type in 'ipconfig /all' again. Check that the IP address you recieved is not 169.254.x.x as this indicates that the device that provides the IP number is having a bad day. Reset this device if you are able. Turn it off and Wait! Best option is make a cup of tea. Then turn the device back on. Let it have at least the time it takes you to drink your just made HOT tea before you retype 'IPCONFIG /ALL' We know you end users!
If you are using a wireless connection that states it's connected. Check that you have put WEP or Security key in correctly. It made state that you are connected. But running the IPCONFIG at command prompt normally says different.
Hope you all are now better.
www.tagware.co.uk
Nov 25, 2008 | Microsoft Internet Explorer 7
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Computers & Internet Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
