I have an aquarius hotpoint wf430 1300spin the machine on a d setting when i press start will not let water through. When i set it on a fast spin the light comes on but not on the door looked light it does not work but after 10 mins the door locked light comes on but flashes. any ideas
  • 15,935 Answers
It appears your main controller/timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On/off button and mini load LED's flashing ON Hotpoint WT540
Make sure there is no water left in m/c, lay hose down to draln completely, try spin again, if still no go, remove motor and check brushes.
Dec 15, 2008 | Hotpoint Aquarius WD63 Front Load...
No fast spin
Could be blockage in pump or filter, if there is a blockage then the m/c will not spin with a lot of water in it.
Dec 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
