Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana side by side not cooling
Had no build up of ice and compressor is hot to the touch.fan on back of fridge is running compressor kicks on then off in seconds
  • lewdeb487 Jan 22, 2009
    the compressor is locked up
Fridge not working indicater flushing
Posted on Jan 24, 2009
    Problem Solver:
  • 18 Answers
Any properly operating compressor will be hot to the touch,that is the way they evaporate water taken from defrosting. On fridge compressors there are two windings, 'run' and 'start'. the start winding will give it the initial boost and the run winding will keep it running for as long as it needs to. If the start winding gives out the fridge will do what you're describing because it's only using the run. you will need an appliance repair tech to fix it. On the other hand, refrigerators also need clean coils and air flow to operate correctly. Try removing any bags, boxes of cereal, brooms, etc. out from on top and around the fridge. Second check your coils, they are either on the back or underneath (behind the snap-in kick plate) and either vacuum them if you can, or use a product alled 'blast-a-coil' or other similar coil cleaning agent to clean them. That should work for you, if not, post again, we'll work on it!
Posted on Jan 22, 2009
  • Super Myke Jan 29, 2009
    What do you mean 'locked up'?
    thorn6 is close with his post. It's not called a 'start relay' but just a relay. The other part you'll find right under it is called the overload. you don't need any kind of equipment or tools to find which one is bad, you just shake them. If you hear a rattle, it's bad, because there is a metallic ceramic disc that creates electrical continuity. If there is an electrical overload, this part will fry and fracture, not your compressor.
  • 700 Answers
Sounds like the start relay on the compressor is bad. take the model number and make to the parts hopuse and have them get you the start relay for your refrigerator. the relay is on the compressor underneith the black cover on the side of the compressor. shut off power and take a screw driver and remove the clip that holds the cover on and you will see the relay. good luck and thanmks for using FixYa
Posted on Jan 21, 2009
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
Fan running compressor not kicking on. canister feels really hot.
check that both wires to compressor are connected, trace them back to solinoid, , if the compressor isnot humming u only have 1 leg of power or it is bad
May 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fan works but the fridge does not coll freezer does not freeze
Does it get cold at all... gots to know...to help hehehehee
Aug 18, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Fridge not cooling
Check the coolant pressure, you could have a leak. Sounds like everything else is working.
Jan 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Nov 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
264 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
