Question about Klipsch Audio Players & Recorders
Klipsch sub-10 amplifier module
Where can I find a replacement?
3 Suggested Answers
  • 56 Answers
SOURCE: klipsch sub 10 keeps blowing fuses
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Posted on Apr 13, 2009
  • 1348 Answers
SOURCE: i have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
Posted on Jan 13, 2010
Testimonial: "helpful"
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
Apr 08, 2014 | Klipsch Audio Players & Recorders
The Fuse blows as soon as I turn the Sub on
Maybe power amplifier end module broken this could be an powerpack ic or transistor output stage cause of shortcircuit or even bad capacitors.
Oct 26, 2013 | Klipsch Sub-12HG Synergy Series 12-Inch...
My klipsch sw112 sub stop working and know when i turn it on it just makes a clicking sound the led light flashes on and off
The sub amplifier circuit is probably damaged and the protection circuit takes over. Have a qualified electronics technician take a look at it.
Oct 13, 2012 | Klipsch SW-112 Speaker
Klipsch sub 10 amp failed , no output
Clearly there is something too highly stressed, badly designed or of inferior quality within the amp but without access to the circuits and more details it is impossible to know what that is.
From experience I would guess the truth of the matter is the company has not designed and/or built the amp itself but has either contracted-out this part of the production or has bought in ready-built amplifiers and adapted them for their purpose. Such a thing is common in commercial production and cuts production costs/increases profits drastically. It is not unusual that these practices result in things being short-lived and unreliable...
Those who buy in ready made modules tend to be divorced from intimate contact with the circuits and the components used and often don't possess the required technical expertise for the task and are simply reading specifications and the bottom line and such people have the unfortunate habit of expecting a pint pot to contain a quart...
Considering the increased profits, such people neither want or expect perfect performance or reliability just merely that most of the people most of the time are satisfied and not enough are dissatisfied to affect the overall brand reputation...
Maybe it will be third time lucky for you...
Oct 04, 2017 | Klipsch Synergy Sub-10 Subwoofer Speaker
I have a Klipsch Sub-10 It is NOT working. I am not sure what happened. It was just fine last week. It's powered up and everthing but not throwing any bass. It was also detected during the auto setup.
If you're saying the auto setup produced sound then the sub and its amp are fine.
So we need to examine the source electronics for actual playback settings. Give a hint of what that might be.
Feb 19, 2011 | Klipsch Synergy Sub-10 Subwoofer Speaker
My klipsch subwoofer won't play on my pioneer receiver.
You do not mention if this is a Pioneer VSX type receiver or if it is a Stereo receiver. Assuming the first, you need to enable the Sub-out output. The Owners manual will show you how. Then you should connect from the Sub-out using a good quality RCA type sub specific if possible cable to your Klipsch Sub. Play with all the levels until you are satisfied. It will take some time to set up properly.
Good luck.
Aug 27, 2009 | Pioneer Audio Players & Recorders
MID-RANGE DISTORTION
hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Oct 14, 2008 | Denon AVR-3806 Receiver
Klipsch Speakers 4.1 died suddenly
Humm. Plug some earphones or another set of speakers into the computer and see if you get sound. That will at least point you in the right direction. And not to insult your intelligence but make sure the speakers are plugged into the green port.
Nov 10, 2007 | Audio Players & Recorders
96 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
