Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
I have a Jenn Air Model SVE47600W. The fan starts/stops/starts/stops at certain times of the day. There is a clicking sound, and the oven light goes on and off when this happens.
I have unplugged, and plugged in again. Is there a 'reset' button? The range is approx. 10 years old. Is it worth having it repaired?
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
You have a faulty EOC board and it will need to be replaced. Here is the part to order. To replace the board, remove the front display cover to access the EOC.
Posted on Jan 07, 2013
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn air sve47600w
with wiring diagram check to see if any power to circuit board. check any limit switches in line in oven circuit. then check the following.sounds like a circuit board problem. turn power off for a minute then try again. also with power off unplug all connections to board and plug back in. if still problem replace electronic oven control board.
Nov 16, 2013 | Ovens
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I cant start the self cleaning process on my Jen-air sve47600w
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 10, 2010 | Jenn-Air JES8850 Electric Kitchen Range
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
www.appliancehelponline.com
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Very old Jenn-Air wall oven (model w100) will not heat
nope..no fuses...time to research a new oven.
May 28, 2008 | Jenn-Air Ovens
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
70 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
