Sharp washing machine es-s900 appear error e3,what's problem?
SOURCE: My instruction manual of Sharp ES-S701X washing
I have a copy, can scan and email to you,let me know, kumanan1950@yahoo.com
Posted on Mar 08, 2010
  • 59 Answers
SOURCE: hello sir ineed assistence with
yes but what is the problem?
Posted on Aug 30, 2010
  • 6277 Answers
SOURCE: I need the manual for
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 30, 2011
SOURCE: sharp model ES-710PF WASHING MACHINE,
HELLO MY PROBLEM IS THE WATER OVERFLOWING THE WATER IS FULL AND E1 ERROR ALARM
Posted on Jun 20, 2011
  • 6277 Answers
SOURCE: MY Sharp ES-S601X washing machine
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jul 10, 2011
Testimonial: "Thanks a lot. It helped and worked."
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What does e3 code ?
The machine can't drain the water away Should the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump situated at the front of the machine for easy access.
Apr 10, 2015 | Hoover Washing Machines
Error code E3..
Manual is here
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-ES-Site/Sites-ES-Library/default/v1427954440473/support/manuals/CWD1510W.pdf
Apr 02, 2015 | EdgeStar 2.0 Cu. Ft. Washer Dryer Combo...
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
Its flashing E3 and chiming. and stopped washing
Hi
E3 is an overload error and indicates that the washer motor is not running properly. You can take out some clothes and then restart the cycle by pressing the START/PAUSE button. After this, if the error appears again then check the motor connections, if everything appears fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Washing machine stopped and door opened and says E3. please help. machine is a bosch wae....
The machine identifies and indicates some operational errors through a series of beeps.E3 is also listed in that beep.the meaning of e3 is nothing but it is telling to call the service engineer.This error signal is due to Thermistor open/short.Thanks for your question.
Jun 19, 2011 | Washing Machines
Washing machine saying 3e starts a cycle then it stops and flashs 3e
The "E3" error indicates that a washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
A 3e error is a possible drain clog,Remove drain line and check for any clogs.
Apr 25, 2011 | Washing Machines
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
