Question about Sony CDX-L480X CD Player
Sony CDX-L480X CD Player not working - Sony CDX-L480X CD Player
SOURCE: lost code
theres 3 probes underneth on the circuit board maked tp1 tp2 tp3, (can be seen though the radio outter tin case) one or more may be joined across with a blob of solder, join all 3 and they need no code!
jobs a good un!
Posted on Oct 12, 2008
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Posted on Jul 11, 2009
welcomejee
  • 10594 Answers
SOURCE: need a wiring digram for a sony xplod cdx-gt300 cd
Click Sony Support to dwonload installation guide of CDX-GT300
Posted on Oct 22, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
SOURCE: Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Posted on May 10, 2010
I have a Sony CDX L480x fitted in my car, this radio has worked fine since i got the car, unfortunatly when i put the face back on it the other day, none of the buttons will work, volume, source...etc. All...
It sounds like the volume button may be jammed or the volume up switch may be bad. If the switch is open just enough to let some voltage through it locks up the microprocessor. Unless you have a multimeter and know how to check resistance on a switch you would be better having a professional repair person check it out.
Sep 29, 2011 | Sony CDX-L480X CD Player
I just want to no what colour does what job on my sony cdx-l480x player just ripped it out my old car and cant find the wireing diagram
Yellow: battery constant 12v Red: Ignition 12v Black: GND ground White and White with Black stripe: Left front speaker. White is positive (+) Grey and Grey with Black stripe: Right front speaker. Grey is positive. (+) Green and Green with Black stripe: Left rear speaker. Green is positive. (+) Purple and Purple with Black stripe: Right rear speaker. Purple is positive. (+) Blue: Antena remote turn on. Blue with Wite stripe: Amplifier remote turn on. I think thats all of them. Make sure to connect your positives and negative correctly or you will have phasing problems. dreamsystems
Feb 08, 2011 | Sony CDX-L480X CD Player
I would like to fit the cdx-L480X into my caravan
ok that will work fine please tell me what the problem is genrally if ir caravan had a tape player the plug should be the same as this unit uses a uni plug if not there will be a converter for under 5 pounds
Jan 19, 2011 | Sony CDX-L480X CD Player
Hello! My Sony CDX-L480X car radio can't read the CD-s. Could somebody help me to solve the problem?
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning ,then the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence it could reject but the best is do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Nov 27, 2010 | Sony CDX-L480X CD Player
No instructions on tuning radio
The Manual is downloadable from Sony at
http://pdf.crse.com/manuals/3247340121.pdf
Avulon
May 19, 2009 | Sony CDX-L480X CD Player
Sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Feb 17, 2008 | Sony CDX-L480X CD Player
Sony CDX-L480X CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
