I have to installed scanner on compact - Office Equipment & Supplies
Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
May 24, 2012 | NEAT Receipts Mobile Scanner
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
My odl hp 3052 scanner drive cd is not compatabel with win 7 kindly suggest
Hi
The Hp LJ 3020 is compactable with windows 7, Click hear and install the windows os driver.
Jun 10, 2011 | HP LJ 3020 All-In-One Printer / Scanner /...
Where can i download installer for the scanner
You can download the installation driver and software from manufacturer's site by clicking this link
On the page which opens:
  • Select the operating system of your computer (Windows Xp/ Vista..) from the drop-down list
  • Select the Language (English) and click the Search button
  • Download and install the drivers and software from the next page which opens.
Hope this solves your problem. Thanks for using FixYa.
Jan 28, 2011 | Brother DCP 165C Compact Color Inkjet...
How to install the printer and the scanner
connect the printer with a cable to the computer
install the CD that came with the printer and your are done.
Incase you dont have the CD donload the driver from manufacturer's website, which in your case would be http://www.brother.com/html/download/index.htm
Jan 11, 2011 | Brother DCP 165C Compact Color Inkjet...
How to install cannon scanner
there is a compact disk given given with that scanner.install it then ur scanner will work automatically
Mar 24, 2010 | Office Equipment & Supplies
I need a step by step on how to download frequencies form radioreference.com to my Uniden 396-XT scanner.
You didn't mention whether or not you have software to handle the download/programming. If you don't already have it, you'll need a package such as ARC-XT or ARC-XT-PRO from BuTel, along with a premium subscription to RadioReference. Once you have the software installed you just click "DOWNLOAD," select the systems that you want to add to the scanner, and then sit back and listen. The "PRO" version of the software also allows you to control the scanner from your PC, log activity, and even record conversations on your hard drive. I have the system running on a BCD396XT and a BCD996XT, and it's fantastic!
Oct 31, 2009 | Vtech Uniden BCD396T Compact Digital...
Can I install the Mustek 600 usb scanner to a windows xp?
this is not compact able with Xp but you can try this it may work or not ................
Everybody who ownes a Mustek 600 II N scanner and want to install it under XP will notice it won't work. Mustek's website says the scanner is not supported under Windows XP.
I've tried this and it works fine here:
- Download the NT4 driver from http://www.mustek-europe.com/eng_/html/treiber/scanner_P_n.htm (select the exact drivers by looking up the first two letters of the serialnumber found under the barcode on the backside of the scanner)
- Before installing the driver click right on the .exe file and go to properties, compatibility and select 'Windows NT4' from the pulldown menu.
- Now install the drivers and it should work. I'm running Windows XP PRO here but i'm sure it will work under XP Home too.
If you own another, unsupported Mustek scanner you can try the same. Maybe it will work.
good luck................
Jun 11, 2008 | Office Equipment & Supplies
Program
Radio Shack has a manual for the PRO-83 scanner online in Pdf format. It worked great for me and I honsetly could not tell any difference in the PRO-83 and my PRO-84 !! It worked great for me and I had my scanner set up and working very quickly!! Hope this helps you all as much as it did me.. the manual is for the PRO-83 200 Channel compact scanner w/signal stalker search and lighted keypad.
Hopes this helps you all !!
http://support.radioshack.com/manuals/ome20-501.pdf
Aug 21, 2007 | Radio Shack Pro-84 Handheld Scanner
13 people viewed this question
jasbo
jasbo
