Question about iHome 2go 9IH507B KSAFD0750200W1US switching power supply ac adapter
I need a new AC/DC adaptor 9IH507B - iHome 2go 9IH507B KSAFD0750200W1US switching power supply ac adapter
Need know what voltage ac for tablet
I would be surprised if any tablet required an ac voltage. Such devices as phones, tablets, laptops and other small computerised devices almost universally use a regulated and smoothed low voltage dc power adaptor.
Jan 25, 2017 | Tablets & eReaders
My kindle fire will not take a charge. I have had it for about 6 years.
Kindle Fire tablets are notorious for having the AC adaptor and/or the port where it plugs in to the device wear out. I've had three of them wear out when the devices were barely a year old. At six years of usage, you're way ahead of the game. It's possible that you'll be able to recharge your Kindle Fire if you purchase a new AC adaptor, but if the problem is in the tablet itself and not in the cord, you may have to replace or repair the tablet. You didn't say whether it's still under warranty or not, so hopefully you renewed your warranty and won't have to pay for a new one. If it's no longer covered, and you have to pay for a new one, I'm sorry. The good news is that the newest Kindle Fire HD's have the p lug in port set at an angle, which helps prevent it from wearing out so quickly.
Nov 25, 2016 | Tablets & eReaders
What output volt and amp USB charger should I buy?
afunta.com
What does the manufactor recomend?
Jul 02, 2014 | Afunta
My Kocaso M1062 will not take a charge and says connect charger.
The power Cell (Battery) no longer accepts a charge. The exception is if the AC/DC charging adapter has failed. See if you have a similar power charger around the house. Look for the same type of male pin and proper DC or AC Voltage plus Amps as listed on the current Tablet Charger. Never leave chargers in the electrical outlet alone as they can be damaged by surge power. Try another charger and if that fails also, the power cell in the tablet needs replacing.
Dec 19, 2013 | Kocaso Tablets & eReaders
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
The power light is off The charger is OK with 19Volt The connector is OK and somehow there is a problem with in the power
remove the battery, connect the ac adapter and turn on the laptop. If it turns on then it's your battery. If it doesn't turn on then it is either your ac adapter, your dc jack, or your system board.
If it doesn't turn on then try a different ac adapter from your local pc shop or electronics store. If it still doesn't work then try moving the ac adapter connector and see if it attempts to turn on. If it does then it's your dc jack. If it is your dc jack then you will have to replace it. The problem with that is that it can be pretty expensive to replace it.
The way I have solved this is by ordering a dc jack on ebay or any other online parts supplier and replacing it myself. If you can take your computer apart and put it back together then it's just a matter of desoldering and soldering the new one. If you want you can have a pc or tv shop do the soldering for you.
Have fun and let me know if you have anymore questions.
Dec 14, 2010 | IBM ThinkPad X60 Tablet PC
The laptop would not boot up. It was hooked up to an external screen and then a few hours later, there was nothing on the screen. It wont boot up into a POST screen
Dead Laptop?
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Acer TravelMateĀ® C314XMi (G16012) Tablet...
I was charging it then after i come back it won't switch on
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adapror and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
Hope this helps.
Nov 04, 2010 | Samsung Galaxy Tab Tablet PC
How do I install a DC-IN harness on my laptop: toshiba satellite r15-s822
you actually have to take the bottom of the laptop apart theres alot of screws. once you take it off just unplug the dc adapter and attach the new one i just did it my self.
Jun 20, 2008 | Toshiba Satellite R15-S822 Tablet PC
iHome 2go 9IH507B KSAFD0750200W1US switching power supply ac adapter Logo
16 people viewed this question
Top iHome Tablets & eReaders Experts
Are you an iHome Tablet and eReader Expert? Answer questions, earn points and help others
