Question about OEM 2006 Chevrolet Optra Factory AM/FM Radio Cassette CD MP3 Player
How to change map sensor on chevrolet optra 2006
I want to replace map sensor
2006 HHR with check engine light flashing. Codes
code 300 means multiple misfire due to plugs, wires, fuel problem including injectors.. A P0106 could be caused by:
  • Bad MAP sensor
  • Water/dirt intrusion affecting MAP sensor connector
  • Intermittent open in the reference, ground, or signal wire for the MAP sensor
  • Intermittent short in the reference, ground, or signal wire for the MAP sensor
  • Ground problem due to corrosion causing intermittent signal problem
  • A break in the flexible air intake duct between the MAF and the intake manifold
  • Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
Using a scan tool, watch the MAP sensor value with the key on, engine off. Compare the BARO reading with the MAP reading. They should be roughly equal. The voltage for the MAP sensor should read approx. 4.5 volts. Now start the engine and look for a significant drop in the MAP sensor voltage indicating the MAP sensor is working. If the MAP reading doesn't change perform the following:
  1. With the Key on, engine off, disconnect the vacuum hose from the MAP sensor. Using a vacuum pump, pull 20 in. of vacuum on the MAP sensor. Does the voltage drop? It should. If it doesn't inspect the MAP sensor vacuum port and vacuum hose to manifold for a restriction of some kind. Repair or replace as necessary.
  2. If there are no restrictions, and the value doesn't change with vacuum, then perform the following: with the Key on and engine off and the MAP sensor unplugged, check for 5 Volts at the reference wire to the MAP sensor connector with a Digital Voltmeter. If there is none, check for reference voltage at the PCM connector. If the reference voltage is present at the PCM connector but not the MAP connector, check for open or short in the reference wire between MAP and PCM and retest.
  3. If reference voltage is present, then check for existing ground at the MAP sensor connector. If it isn't present then repair open/short in the ground circuit.
  4. If ground is present, then replace MAP sensor.
Oct 10, 2014 | 2006 Chevrolet HHR
Emplacement position camshaft sensor
If it has a cps. It will most likely be located near the back top off engine where it bolts to the bell house ing
It senses the flywheel turning which in turns means that the crank is turning
Mar 01, 2014 | 2005 Chevrolet Optra Alternator, 05
Optra 2007 hold light is flashing and i changed the gear oil but the problem still
either ur crank sensor is faulty or hold switch on shifter console.
Sep 28, 2013 | 2007 Chevrolet Optra 1.6
Chevrolet optra mass air flow sensor
Hello: Thank you, my problem is similar problem is with Optra Design, but you change the Oxygen Sensor, MAF Sensor, Fuel Pump and still the fault persists engine revolutions down to almost driving off in full , I turn it off and return to continue driving for a while and fails again
Jul 18, 2013 | 2007 Chevrolet Optra 1.6
2006 cobalt ss 2.4 automatic trans. check engine light code p0010 p0106
Code P0010 Intake camshaft position actuator solenoid control circuit ( CMP )
most common cause is a bad solenoid, but it could be many componets that could cause the code, if you want to try to repair it on your own the only thing you can do is replace the solenoid, all other componets require some speclized test equipment.
code P0106 manafold absolute pressure sensor ( MAP )
check for a good vacuum source to the MAP sensor if there is a good vaccum source then replace the sensor.
good luck
Oct 19, 2011 | 2006 Chevrolet Cobalt
I am trying to locate where the map sensor is on my 2006 Chevrolet express 1500 4.3 van. I need to install a new one have the part but need to know where it goes.
I don't mean to be critical, but if you do not know where the MAP Sensor is, then you could not possibly have tested the MAP Sensor circuits. If the MAP Sensor circuits have not been tested, then there is no way that anyone can be certain that your vehicle actually needs a MAP Sensor. (Many MAP Sensor codes cannot be fixed by replacing the MAP Sensor itself.) Then again, you might just get lucky.
To answer the question you asked, The MAP Sensor is located on the passenger side of the intake manifold near the rear of the engine. You must remove the doghouse to get to it.
I recommend that you also review this article: What Else Could Be Wrong?
I wish you luck!
May 09, 2011 | Chevrolet Express Cars & Trucks
OEM 2006 Chevrolet Optra Factory AM/FM Radio Cassette CD MP3 Player Logo
103 people viewed this question
Top OEM Audio Players & Recorders Experts
Coss
John
John
Are you an OEM Audio Player and Recorder Expert? Answer questions, earn points and help others
