Question about Datel Action Replay for Nintendo DS
Doesnt update codes
I erased all the codes and when i put the code it tell me that there is no free space
  • Anonymous Mar 14, 2009
    Yeah, when I try to update my codes, it says that there's not enough free space. When I look at my current codelist, there's NOTHING in there, and whenever I put in a game the AR says 'Unknown game'. By the way, that "hold a and b then hold start and select then release" thing? IT DOESN"T WORK.
Put ur AR cartridge in your ds hold both A and B then Turn the ds on when the ds safety screen comes up hold Select and start then when the AR screen: this product is not licensed or endorsed by nintendo: comes up then release all buttons this should work
Posted on Jan 24, 2009
Im getting cylinder 5 misfire codes after driving on E and filling up. Could has gas have clogged my injector? I've changed the spark plug and ignition coil already and same error codes
Try by erasing the code. The computer thinks its still having the same code. if no way to erase code, then go to any auto parts store. auto zone etc, tell them you think the code is fixed, and they should erase code for free. with scanner. God-Bless!
Apr 25, 2016 | Cars & Trucks
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
My phone memory is showing full but there is nothing in the phone memory. and message is not coming on my mobile. it is nokia 6303c
If the phone memory reach the remaining free space,it may result to save some data and eventually error takes place no matter erasing some data on phone memory,the solve this problem,reset your phone by going to settings and restore factory settings.a code will be ask then enter the desire code or the default code is sure to back up everything before proceeding with this method because everything will be erased after the process.
or just type *#7370# , a code will be ask then enter the code.
Good Luck...
Aug 27, 2011 | Nokia 6303 Cell Phone
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
The player tells me there's not enough free space for music DB and I need to free 30 mb. At that time the player was empty. I've erased the disc and it still gives me the same message. What's the deal.
try formatting the disk and then if that doesnt work run a scandisk check on it.if even that doesnt work,use sansa updater that may have come in the CD provided alongwith the player.
Sep 06, 2009 | SanDisk Sansa Clip MP3 Player
I downloaded the AR code manager,and it doesnt recognize the AR
Then your ds card slot where you put the game or action replay might need cleaning i use a dry Q-tip and rub very very gently or your action replay is busted :P hint do not put in too many codes my mistake let just say its a magic eraser :P
Jul 02, 2009 | Nintendo DS Lite Console
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Jun 13, 2009 | Datel Action Replay for Nintendo DS
How do i clear the codes on my cavalier
if you take your car to autozone they will put it on a code reader and tell you what codes are there and they will erase them for free
Mar 18, 2009 | 1998 Chevrolet Cavalier
Coppying problems
Note: this method erases all songs - starts you over:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
-Tha Mp3 Doctor
Apr 08, 2008 | SanDisk Sansa e250 MP3 Player
Datel Action Replay for Nintendo DS Logo
75 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
