Question about Brother Sewing Machines
The sewing maching stops while it is sewing - makes a squeeling sound and has a E6 error message, but I don't see any thread anywhere that could be causing the problem
The sewing machine is a couple of years old and has not had any maintence done to it at all
  • Brother Master
  • 7,365 Answers
Try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way
try another bobbin
try a new needle-one that is for the fabic being sewed
if none of these suggestions help then it would be a good idea to
have the machine serviced
Posted on Jan 07, 2013
SOURCE: E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Posted on Dec 27, 2006
dizzythevamp
  • 9 Answers
SOURCE: Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
Posted on Jan 06, 2009
dizzythevamp
  • 9 Answers
SOURCE: E6 and F5 error message
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
SOURCE: I get an E6 message while trying to sew on my Brother cs-6000
Here is the online manual for your machine. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Posted on Mar 30, 2009
  • 46 Answers
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Posted on Jul 25, 2009
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
Feb 02, 2018 | Brother Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
How do you clean brother SQ9050
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide this is important for the tension
try using a different bobbin
clean under the needle plate and in the bobbin area for lint
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
I have a Brother XR6600 - today I got an E6 error indicting tangled thread. Ihad a check and cleaned it but no thread. When I try to sew the machine jam's ..... Help!
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
Jun 05, 2012 | Brother Sewing Machines
My top thread is not picking up from the spool
rethread the machine top & bobbin
make sure the bobbin is not warped or damaged
also make sure the bobbin case is not damaged
if these suggestion don't help then it would be a good idea to have the
machine checked at a sewing machine shop to see what is wrong with it
May 31, 2012 | Sewing Machines
E6 error code on cs6000i
it's possible that it's a mechanical or electronic problem or something has worn or is loose, it needs to be serviced
Feb 06, 2012 | Brother CS6000i Computerized Sewing...
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Aug 24, 2009 | Brother XL-3510 Mechanical Sewing Machine
Machine is telling me E6 error but there is no thread tangled
If your thread is not tangled .The E6 will come up also if the top thread is not threaded properly. Is your thread breaking at all ?
Dec 13, 2008 | Brother CS-6000
E6 error on CS-100, thread underneath all knotted and tangled, makes grinding sounds.
Your bobbin is not wound correctly. Check and see if your bobbin thread is wound to loose or unbalanced.
Oct 25, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
